Recommend ADSL wireless router please
chilli
For the in-laws - I said I'd help them out getting wireless working.
Not really looked at the market recently but can anyone recommend a basic router that meets the following:
Readily available
Good value for money
Reliable (runs without needing reboots etc)
Easy to set up / keep running (I won't be around to fix it for them all the time)
ADSL port
Wireless 802.11b/g
Good wireless range (poss with diversity aerials)
WEP128/WPA
DHCP
probably some ethernet 10/100 ports (1-4) would be handy for their local PC
All they want to do is share the wireless between a local desktop PC and a laptop that is typically upstairs
so wired ethernet from the desktop and wireless for the laptop sounds best for the moment...
easy peasy but I don't want to recommend a duff router to them
Do they HAVE to be connected via a wire to at least one computer or can they be used completely wireless?
Well the existing desktop PC is right by their current ADSL USB modem AFAIK.
So I'm thinking the router replaces their USB modem and they use ethernet rather than USB to get a wired connection to it.
but that reminds me, they will need an ethernet card too then. At least they are as cheap as chips
could of course fit a wireless card in that too though. I know they are not expensive. Just figured they would get the best performance on the desktop over ethernet and the wireless won't then be shared so that will be as fast as it can be too...
A wireless router will allow you to connect to your ISP service automatically, and manage the home network by assigning an IP address to computers which sucessfully authenticates and connects to the wireless router.
most routers have ethernet ports on the back of the router which allows you to connect the computer directly to the router. for wireless connectivity you can either use a wireless usb pen, or wireless adapter which plugs into your pci card, or if your motherboard has all the bells and whistles, it may even have wireless support..
We only really sell Netgear and Dlink. We do some cheaper MSI and Belkin ones, but out engineers prefer Netgear (If the client won't stretch to Cisco that is!)
Netgear routers are a peach to install and run.
DLink can be a pain.
Both v.simlar prices.
I have a Netgear WGR614 sat here at home.
I've just been attempting to get mine set up. Just got a DLink from a member on here - plugged in the power and phone line and switched on the wireless bit on the laptop. I can connect to the router but can't work out how to get it to connect to the internet:( Given up for now - looks like I might have to pay someone to come an set it up for me :( :(
thanks, but I knew this already lol.
that's why I asked for ethernet, DHCP etc, all fairly standard features that I need.
The laptop (like many modern ones) has wireless built in (like the one I'm using right now)
Their desktop doesn't, but I can add a wireless card if I have too. Wired would be better though since it is co-located with the router.
where you live, I'll come and do it if you're paying lol :)
cheers, thanks.
Using a d-link here, an old one and I find it needs a reboot every so often as it starts messing up connections.
I've heard good things about netgear, might see what is recommended in their range then
I did one yesterday Chris, the bloody thing just didn't want to play ball.
Do you have any connections setup already? I assume you've put your user/pass in ok?
I think so - TBH I'm not too sure what I've done with it now - had a screaming baby over one shoulder and trying to do everything one-handed LOL.
Pete whats the best make that is Mac OS X and WIN XP compatible ?
Netgear site says NO
Belkin says YES
DLink and LinkSys conflicting info ?
Just for surfing wirelessly is 54 G okay in a standard size 3 bedroom house with the router connected via ethernet to a Mac on OS X upstairs and a notebook on XP downstairs ?
:p
