Soonto_HAS_soop Posted September 30, 2006 Share Posted September 30, 2006 Is there such a thing as too large an oil return for a single setup? Link to comment Share on other sites More sharing options...
uk-rich Posted September 30, 2006 Share Posted September 30, 2006 can't see how, unless its so big that it is impossible to get it to fit Link to comment Share on other sites More sharing options...
TLicense Posted September 30, 2006 Share Posted September 30, 2006 I don't think so. I think the relationship between the inlet and the return might be important. ie If the inlet was huge, you might need a larger return so as not to over pressurise the turbo. But at the end of the day it's just a drain for the oil that's been fed to it. Link to comment Share on other sites More sharing options...
SimonB Posted September 30, 2006 Share Posted September 30, 2006 The drain can't be too large. It can be too small, and the feed can be too large, but not the drain. Link to comment Share on other sites More sharing options...
JohnA Posted September 30, 2006 Share Posted September 30, 2006 It can't be too large, but it can be not steep enough. It has to give gravity a chance, no more than 30degrees from the vertical axis at any point (ideally) Link to comment Share on other sites More sharing options...
