Ewen Posted September 28, 2006 Share Posted September 28, 2006 Am I right in thinking the throttle cable on a Tiptronic VVTI is only there for kick-down ? Or is it also for limp-home mode ? The VVTI is true FBY isnt it ? I'm being given advice I dont trust. I've searched, but cant find a thread I remember seeing last year. Link to comment Share on other sites More sharing options...
Guest Terry S Posted September 28, 2006 Share Posted September 28, 2006 Its used as a reference point by the electronic throttle. Link to comment Share on other sites More sharing options...
Ewen Posted September 28, 2006 Author Share Posted September 28, 2006 Its used as a reference point by the electronic throttle. So, although the cable moves with the throttle, the actual throttle setting information from the pedal is electronic ? If so, my new found friend isnt an 'expert'. Link to comment Share on other sites More sharing options...
Alex Posted September 28, 2006 Share Posted September 28, 2006 The bit on the throttle that the cable moves is the APP Actual Pedal Position sensor. This x-references with the TPS and the two together work out how far the throttle should open...which is done by a gear set under the right hand side black cover. Link to comment Share on other sites More sharing options...
Guest Terry S Posted September 28, 2006 Share Posted September 28, 2006 as Alex says it has 2 TPS that cross reference Ewen. Link to comment Share on other sites More sharing options...
Ewen Posted September 28, 2006 Author Share Posted September 28, 2006 Thats great...thanks for that. Link to comment Share on other sites More sharing options...
Pete Posted September 28, 2006 Share Posted September 28, 2006 Interesting. I wondered why the fly by wire system had a cable! Link to comment Share on other sites More sharing options...
Alex Posted September 28, 2006 Share Posted September 28, 2006 Interesting. I wondered why the fly by wire system had a cable! The cable is also the mechanical limp mode safety net... If your throttle goes into limp mode then the last 15% of throttle travel is a mechanical override and allows you to get to safety. But it is a bit wierd trying to drive slowly and safely with your foot buried to the floor... Link to comment Share on other sites More sharing options...
Ewen Posted September 28, 2006 Author Share Posted September 28, 2006 The cable is also the mechanical limp mode safety net... If your throttle goes into limp mode then the last 15% of throttle travel is a mechanical override and allows you to get to safety. But it is a bit wierd trying to drive slowly and safely with your foot buried to the floor... I'm an expert now....daily practice. Rush hour roundabouts are a challenge though. Link to comment Share on other sites More sharing options...
Alex Posted September 28, 2006 Share Posted September 28, 2006 I'm an expert now....daily practice. Rush hour roundabouts are a challenge though. Lol yeah - always when pulling up to a roundabout. Link to comment Share on other sites More sharing options...
