fiddly job pls help with answer
jaiscossie
have a wire come off behind the dash now its to short to pull through to connect back together (its inhalf) so trying to think of a way to join it, can get my hands through hole under stereo but is tight. no room for crimpers or such as wire is to short and really dont wanna have to take whole dash apart
5 mins. but as its your first go about 3 hours..lol.. NO not really. its easy. 1 take the ashtray out.(just pulls up) 2. handbrake up and select N. 3.pull gear surround bit up carefully. 4. then undo the 5 srews along the top bit. 5. unplug all the plugs(they only go back in one place) so don't worrie about what goes where. 6. carefully pull the clock surrond off(just clips) and then remove the bit around the stereo. this can be a sod. as too can the air con plug to get out. but it wiil come out.
