Mot Test
kornboy119
Hello,
I have found a FOG light conversion manual from this forum. It is the one which converts two of the rear fog lights to light up as fog lights. Will this allow the MOT to pass, as there are two lights used for the fog lights and also as there are no indications of the fog lights being on, on the dash board?
This is what the lights look like when the fog lights are on.
Strictly speaking it shuld fail the MoT, as the distance between the 'fog' lights and the brake lights isn't enough. if you look at UK cars you'll notice that the lights are in a different order to accomodate UK law.
Anyway, I did it and took it to get MoT'd and the tester knew the score but he said his eyes were dodgy and it passed ;)
You MUST have an indicator of some description that the fog lights are on (when they are!) - simply buy a rocker switch that glows when it's 'on' - that's what I did - job done. :)
This fog conversion won't fail the MOT for the fact it has 2 fog lights, The UK spec Supra has 2 fog lights, as have a number of other cars, the MkIV escort to name but one.
As has been mentioned technically it could fail on the fact that the fog light isn't far enough away from the brake lights, but the Reverse light mod would suffer the same problem.
The Fog lights work as fogs when the fog light is on, and as brake lights when it ishn't so you won't lose 2 brake lights :). I have an LED wired into the fog circuit, but as mentioned you can get illuminated switches. The big thing to point out is that if the tester has his foot on the brakes (and it seems that most do when the fog light is switched on, then he won't notice the fog light come on - I found my tester was happy when I told him "to lift his foot off the brake" that the fogs remained on.
One point to note is that unless you fit the resistors in the circuit, the bulb fail light will come on if the brakes are depressed with the fogs on, THIS IS A FAIL.
I never had any problems with my MOT, but I left it so I could revert back to caravan-o-fog if needed.
Mike
Although they didn't notice this on mine (I left the conversion to the last minute and couldn't get the resistors in time) and it passed :)
I had mine done too, just fitted a small illuminated switch which I tuck away for the other 363 days of the year. The bulb failure system has to be bypassed though. It flew through the MOT,....
Bad news is my LED brake light has half the LED's out. I've disconnected it because none is better than only half working. can anyone help with a replacement unit?
