Build up of a Big Single Auto , step by step
dude
  • Replies 298
Posted Images
Next bolt the oil drain to the block where the original one goes re-using the metal gasket, make sure the braided line is pointing up and that you screw the adaptor into the alloy block using the taper thread or it WILL leak
Now is a good time to clean up the block (did mine just before i left for home) cause its a lot more exposed than with the twin boat anchors fitted !!!!
As soon as the cams and pulley and springs and head studs get here i'll throw it back together and take more pics , tommorrow i'll get some of the fuel system mods .
Dude:flame Dev
Originally posted by Kean
Dude,
Your -10 oil drain hose is the wrong direction!! The 45 degree is supposed to be connected to the turbo. The straight portion is connected to the oil pan.
Pics look great =)
Edited to say oops i see what you mean now , i thought it looked a bit funny when i bolted the other adaptor on the turbo , now i see why !!!!!
Dude:flame Dev
Good work dude,
I did the same thing a couple of weeks ago now, by far the hardest part is getting the stock twins off, a real pitter.
Only difference is mine is an induction motorsport kit and a manual.
:thumbs:
Originally posted by Ian C
Did you have to angle grind down the exhaust manifold studs?
-Ian
Ian the reason you have to grind the studs is that because the header is now tubular and larger bore as you place it over the studs the bottom ones allmost touch the header thus you need to take a bit off so you have clearance , you will also have to put all the bottom nuts on before you put the top nuts on. :thumbs:
Dude:flame Dev
Dude:flame Dev
I wasn't criticising the kit fitment, I just weondered as I heard you *may* have to but now I know you *will* have to :)
-Ian
Originally posted by Terry S
dude, it would be interesting to see the weight between the stock twin set up and the BL kit if you get a chance??
Have you seen this site , Terry?
It lists the weights of the stock turbo assembly and the equivalent Boostlogic parts. The turbo they weighed is a PT63.
It would still be good to get confirmation though.
Regards,
Cliff
Guest SpeedUp
Very nice pictures dude :cool:
I'm going AT/Single too. I bought the (small) BoostLogic T61 (.68) and the tranny-upgrade with a 3800 stall.
(ECU=PHR Map Ecu)
Hope everythink works well.
cheers,
Marc
Guest Terry S
Sorry dudes forgot the camera, but 2 walboros do fit in the stock swirl pot !!!!
Dude:flame Dev
That wasn't exactly a news flash mate!
I'll call you in the morning.
Yeah but i got them sideways !!!!!
Dude:flame Dev
Seriously it was tight getting 2 in with no cutting !!!
Ah, another good pointer, I hadn't thought of fittiing the two pumps into the baffle area of the tank, did you have them side by side, staggered, or in a line? (where in a line = one nearer the front of the car, one nearer the rear)
-Ian
-Ian
As you look down into the tank 2nd one slightly staggered in front of the original to the left , i'll post pics soon , its tight but can be done !!!:D
Dude :flame Dev
