Thinking of going single
jayssupra
BL67/SP67 or PHR2 would be ok for that mate, i'm in cleveland and should have my single on again in a few weeks. Can give you a spin then if you like?
My SP850GT on the old supra made 570RHHP on Thor's dyno so i called that 570bhp at the fly, was perfect for the road (until i broke it :whistle:)
I fitted a PHR stage 1 single which i'm running between 1.2-1.3 bar at the moment and it made 497.8bhp on saturday. Im really impressed with it! Even on a auto its not laggy and the performance is really impressive compared to my old BPU. The boost comes in really strong @ 3200 rpm. I'm just in the process of sorting out some other bits and pieces before i wind the boost up :)
1.2-1.3 bars of boost, what sort of boost can you turn it up two.
29psi=2bar it can go upto with the correct fueling system etc
"The PHR Stage 1 is capable of 520 RWHP at 18 psi utilizing the factory fuel system and electronics, or 630+ RWHP at 29 psi using the PHR Stage 2 Fuel System upgrade and MAP ECU. "
http://www.powerhouseracing.com/files/catalog.php?make=Toyota&model=Supra%20TT&catagory=Single%20Turbo%20Systems
Nice! What was the power at the wheels?
Which injectors and ECU are you using?
Cheers matey i was quite impressed i have loads of print outs from the different runs that were done whilst tuning so not sure of the final RWHP figure need to have another look. I went for the PE injectors as they are supposed to be good and greddy emanage ulimate which is now hooked into the incarpc for datalogging etc :)
