carl0s Posted April 9, 2004 Share Posted April 9, 2004 Should there be something in this box? It looks like it's been dry for quite some time. http://www.amtleasing.co.uk/supra/coolant.jpg Quote Link to comment Share on other sites More sharing options...
Steve Cargill Posted April 9, 2004 Share Posted April 9, 2004 Erm, yes!!! On the left side as you look at it there is a Min and a Max line. It needs to be topped up with coolant to between those marks. When the engine is cold take off the radiator cap. It should be full. Quote Link to comment Share on other sites More sharing options...
carl0s Posted April 9, 2004 Author Share Posted April 9, 2004 i've just been trying the radiator cap, but I can't get the fecker off - it has folded edges underneath... what's the crack? BTW there is a hose coming into this coolant box that goes to nothing - am presuming this is just to allow air to fill where the coolant comes out? Quote Link to comment Share on other sites More sharing options...
carl0s Posted April 9, 2004 Author Share Posted April 9, 2004 hey I just had another thought. Any chance that this could be related to my air con not working? Oh yeah and what kind of coolant should I be buying from halfrauds then? It's a UK spec. thanks, Carl Quote Link to comment Share on other sites More sharing options...
Steve Cargill Posted April 9, 2004 Share Posted April 9, 2004 For the rad cap, push down and twist anti-clock I think, should take about 1/3 turn and pop off. The tank is called an expansion tank and yes the other pipe is just a vent for air and also to safely blow any exess coolant out. Quote Link to comment Share on other sites More sharing options...
carl0s Posted April 9, 2004 Author Share Posted April 9, 2004 thanks Steve. It's this full: http://www.amtleasing.co.uk/supra/rad.jpg Basically it's full to the top as far as the actual radiator itself goes, but not full to the cap if you know what I mean. Quote Link to comment Share on other sites More sharing options...
Steve Cargill Posted April 9, 2004 Share Posted April 9, 2004 I'm pretty certain that it should be right to the top, can't quite remember. At least the core is covered so you arn't dry. I've always used Toyota 4-life, do a search, I'm sure there are a few suggestions. Quote Link to comment Share on other sites More sharing options...
toyotasuprauk Posted April 9, 2004 Share Posted April 9, 2004 That level looks ok but sadly not related to your air con. That probably just needs a re gas. Quote Link to comment Share on other sites More sharing options...
Terminator Posted April 9, 2004 Share Posted April 9, 2004 That fluid level is very low, it should be right up to the top of the neck of the rad. The white box should be filled to the max mark. Quote Link to comment Share on other sites More sharing options...
carl0s Posted April 9, 2004 Author Share Posted April 9, 2004 only one problem now. Some fool went and filled the white box about an inch above "max", and with undiluted coolant. is that bad? Quote Link to comment Share on other sites More sharing options...
Nick_TC Posted April 9, 2004 Share Posted April 9, 2004 The fool wants a slap If I were you, I'd get a full system drain/refil done, if your running Toyota Forlife coolant, iirc it cannot be mixed with anything else, but Toyota Forlife coolant. Quote Link to comment Share on other sites More sharing options...
Jake Posted April 9, 2004 Share Posted April 9, 2004 Originally posted by NWS25 Toyota Forlife coolant, iirc it cannot be mixed with anything else, but Toyota Forlife coolant. Oh no ! I put some water in mine the other day !!!!1 :D Quote Link to comment Share on other sites More sharing options...
Nick_TC Posted April 9, 2004 Share Posted April 9, 2004 More fool you then, you should top up with coolant not water Pubs shut already?? Quote Link to comment Share on other sites More sharing options...
Jake Posted April 9, 2004 Share Posted April 9, 2004 Originally posted by NWS25 Pubs shut already?? Quote Link to comment Share on other sites More sharing options...
Jake Posted April 9, 2004 Share Posted April 9, 2004 Originally posted by NWS25 More fool you then, you should top up with coolant not water Is that true? Quote Link to comment Share on other sites More sharing options...
Steve Cargill Posted April 9, 2004 Share Posted April 9, 2004 Originally posted by Jake Is that true? Yes., very true. It keeps the concentration up and the fulid fresher, using water will dilute it - there are probably other reasons also. Quote Link to comment Share on other sites More sharing options...
Jake Posted April 9, 2004 Share Posted April 9, 2004 I see. What about if you were unsure what coolant was in there?Given what Nick said about some coolants should not be mixed with others I suppose it'd be safer to top up with water then, correct? Quote Link to comment Share on other sites More sharing options...
dandan Posted April 10, 2004 Share Posted April 10, 2004 I used deionised water and a good antifreeze when I flushed mine through. Quote Link to comment Share on other sites More sharing options...
Terminator Posted April 10, 2004 Share Posted April 10, 2004 IMHO it is better to run{for a short time) with the addition of water to the system rather than add nothing. If you nkow how much water you added you couldalway syphon the same amount out and replace with the red stuff, the additional dilution would probably be negligible. Quote Link to comment Share on other sites More sharing options...
Scooter Posted April 10, 2004 Share Posted April 10, 2004 there's a long thread in Mkiv.com about doing a coolant change, in which it says about adjusting the coolant /water ratio depending on the climate range the individual car will see. Anyone do that.......i doubt it....... I can't see topping up with water doing any harm unless its a continual situation that will lead to higher dilution over time, but this would point to something else probably being wrong anyway............ Quote Link to comment Share on other sites More sharing options...
