DannoSupra Posted September 25, 2006 Share Posted September 25, 2006 Fitted my Defi's yesterday, i took a ign feed off my apexi avcr and hks fcd for the controller. Ever since then, my dash is like a xmas tree, engine light, trc off, o/d off flashing, warning triangle... also what i did, i had the ignition on when my speedo and waring light cluster was disconnected and connected it up when ignition was on. it drives.. but it hits fuel cut when 2nd turbo kicks in... anyone come across this before, its a UK auto Cheers Quote Link to comment Share on other sites More sharing options...
Scooby Posted September 25, 2006 Share Posted September 25, 2006 No sorry chap. All I can suggest is that you remove the Defi and reset the ecu, just to see if it goes back to normal. If it fixes it you will just need to find anouther feed. Quote Link to comment Share on other sites More sharing options...
Scooby Posted September 25, 2006 Share Posted September 25, 2006 Like your wheels. I was looking at fitting the Tein suspention next month, what do you think of it? Does it improve the handling? Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted September 25, 2006 Author Share Posted September 25, 2006 Ohhh yes! Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted September 26, 2006 Author Share Posted September 26, 2006 Got another source of ignition feed, still, my dash lights are on Anyone? Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted September 26, 2006 Author Share Posted September 26, 2006 Flash codes 34 and 35. Might be something to do with my FCD Have a look after work Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted September 27, 2006 Author Share Posted September 27, 2006 FIXED - Broken wire on the ecu side of where FCD bypasses the Boost Pressure Signal PHEW!!! Quote Link to comment Share on other sites More sharing options...
