V band clamp not sealing
Ibrar Jabbar
I believe turbofit can supply you one of these. I had a bit of trouble with mine as i have a Blue peter downpipe. I loosened the bottom of the downpipe so i had a fair bit of movement then done the Vband clamp up. This way it should pull in a 100% square. Then just bolt the bottom back up again
