scooby_doo_do Posted September 23, 2006 Share Posted September 23, 2006 As above - i have a rev counter on the Humber V8 i've bought, but the cable at the back has been cut. Any ideas where i should be looking to connect it up again? Also, what should a 3.5 rover SDI V8 lump rev too? Or be safe till? Thanks. Craig. Quote Link to comment Share on other sites More sharing options...
jamesmark Posted September 23, 2006 Share Posted September 23, 2006 A rover SDI should rev to around 5k over that there is not much point. My Sarah's grandfather knows the SDI engine like the back of his hand will try and find out more for you, he has built repaired and restored them for about 30 years i think. he loves rovers Quote Link to comment Share on other sites More sharing options...
jamesmark Posted September 23, 2006 Share Posted September 23, 2006 I just called for you mate, 6k RPM is what the SDI engine redlines at. Quote Link to comment Share on other sites More sharing options...
scooby_doo_do Posted September 23, 2006 Author Share Posted September 23, 2006 Cool :-) Now i just need to find where this cable goes to and it'll be all good :-) Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted September 24, 2006 Share Posted September 24, 2006 Negative side of the ignition coil mate Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted September 24, 2006 Share Posted September 24, 2006 A rover SDI should rev to around 5k over that there is not much point. My Sarah's grandfather knows the SDI engine like the back of his hand will try and find out more for you, he has built repaired and restored them for about 30 years i think. he loves rovers Ill vouch for that He was a massive help with my dads MGB V8 (same engine as your Humber mate ) Quote Link to comment Share on other sites More sharing options...
Kranz Posted September 24, 2006 Share Posted September 24, 2006 Yep, negative coil is right. And it'll rev beyond 6K if you let it & finally run out of puff at about 7K as the hydraulic lifters pump up and hold the valves open. I have a couple of these engines.... Ok I have 3! If you need any parts I have one in kit form. As always, for gratis. Quote Link to comment Share on other sites More sharing options...
scooby_doo_do Posted September 25, 2006 Author Share Posted September 25, 2006 Thanks Matt and the others :-) many thanks.. Ok, on to the next stupid question... where's the Negative side of the ignition coil Matt- PM'd you a question as well Quote Link to comment Share on other sites More sharing options...
scooby_doo_do Posted September 25, 2006 Author Share Posted September 25, 2006 Ignore that last one - i think i've figured it out... Going to try it when i get home... Any excuse to hear the sound of the engine again Quote Link to comment Share on other sites More sharing options...
Kranz Posted September 25, 2006 Share Posted September 25, 2006 Ok, on to the next stupid question... where's the Negative side of the ignition coil : Its the one with the minus sign on it mate Quote Link to comment Share on other sites More sharing options...
scooby_doo_do Posted September 26, 2006 Author Share Posted September 26, 2006 Yay - i'm really impressed with myself.. I managed to do it all on my own :-) and it works. This will make you laugh though - I was trying to figure out what cable to attatch it too so i thought the best thing to do was to start the engine and touch the wire on each cable till one worked. So i had decided it was best to place the cable in my mouth whilst i used both hands to start the car... Zap.. My bottom jaw now hurts ;-) Quote Link to comment Share on other sites More sharing options...
Kranz Posted September 26, 2006 Share Posted September 26, 2006 :rlol: And for your next trick you'll be peeing on an electric fence? Quote Link to comment Share on other sites More sharing options...
scooby_doo_do Posted September 26, 2006 Author Share Posted September 26, 2006 And how on earth did i know you'd find that funny ;-) Quote Link to comment Share on other sites More sharing options...
