odd growling noise
miko_supra
It could be something as simple as an exhaust hanger that has come loose, causing the exhaust to resonate at a certain rpm or as complicated as a gearbox problem.
It's very difficult to diagnose a noise from a description, see if you can get it checked out by someone who knows what they are listening for.
Ok checked all the heat shields. they are all fine. its rpm related, not speed, and yes it occurs in all gears. It also disapears when i go beyond 2,500 ish rpm. I has a slight bell like sound to it too. from your replies i do think it is the cat.
Can this be put into the tech section too any one? as i managed to find nothing like this in there, could be helpful to others. :)
