ADD Posted September 22, 2006 Share Posted September 22, 2006 does anybody have a diagram of where all the vsv's are? i have a pipe at the rear of the engine that is badly kinked and it seems like it goes to a vsv of some kind!! any help would be appreciated Quote Link to comment Share on other sites More sharing options...
fredm Posted September 22, 2006 Share Posted September 22, 2006 Look in Club Downloads then Engine then find the thread entitled Vacuum Diagrams. Should find what you want there. You could also checkout http://www.max-boost.co.uk lots of good stuff there. Quote Link to comment Share on other sites More sharing options...
ADD Posted September 27, 2006 Author Share Posted September 27, 2006 great stuff thank you... i have noticed on my car that the pressure tank hoses are really badely kinked, what could this cause? if anything. thanks all Quote Link to comment Share on other sites More sharing options...
JohnA Posted September 27, 2006 Share Posted September 27, 2006 ... i have noticed on my car that the pressure tank hoses are really badely kinked, what could this cause? if anything. If airflow is constricted, then it could take longer to pressurise the VSVs, affecting the synchronisation of the sequential operation. Quote Link to comment Share on other sites More sharing options...
ADD Posted September 27, 2006 Author Share Posted September 27, 2006 If airflow is constricted, then it could take longer to pressurise the VSVs, affecting the synchronisation of the sequential operation. ok mate cheers, that could be why im loosing boost when gears change then? and why it pulls away so badly? the hoses were changed and put like that when the tubbies were replaced a while back by max gt!!!! Quote Link to comment Share on other sites More sharing options...
JohnA Posted September 27, 2006 Share Posted September 27, 2006 It is easy to check if this is the case, with a boost gauge Teed-off the EGCV and the EGBV if needed. If the actuators are not pressurised at the right time, then I'd check the hoses and the tank next. Quote Link to comment Share on other sites More sharing options...
ADD Posted September 27, 2006 Author Share Posted September 27, 2006 It is easy to check if this is the case, with a boost gauge Teed-off the EGCV and the EGBV if needed. If the actuators are not pressurised at the right time, then I'd check the hoses and the tank next. lovely cheers john much appreciated. Quote Link to comment Share on other sites More sharing options...
