Cracked rad
Thorin
Well it's fitted. Easy enough, took me a lot longer than it should though :D
I've done a write up and took photo's, I'll post it up tonight. Had to use some masking tape around the threads of the temp sensor to seal it as I didn't think to go get some proper plumbers tape stuff. It worked, will that be ok or is it likely to start leaking again?
I also used the rad cap from the fluidyne rad rather than the original, I presume it's ok?
edit: and the Fluidyne rad might be slightly lighter than the stock one but there's actually very little in it if so.
Make a new thread so I can easily move it to the FAQ section please :D
-Ian
*as long as you don't mind me moving it, I wouldn't want to abuse my moderator powers ahahahahaha
That was hopefully the idea Ian, but I expect and welcome you to correct/tidy up and just tell me I've done it all wrong before adding it as a FAQ :D
