Car suddenly died!
ChrisSZ
There I was, driving home from work this evening. The only thing out of the ordinary was theat the oil light had stayed on (did this the other day for a while too) - I knew the oil levels were ok so didn't panic too much. Crawling along behind a couple of tractors when all of a sudden the engine died:( :( :Pling:
I have fuel and I definately have a spark at the coil - what are tha chances of the problem being dizzy cap/rotor arm related???
Got the car AA Relay'd home now at least but now I need to know where to start looking for the problem. Where's the best place to buy a new dizzy cap & rotor arm and how much am I looking at??
Any ideas gratefully received:)
dizzy cap and rotor from dealer was between £20-£30 when i brought the pair about a mth ago....
also might be worth checking the big fuses in the fuse box...i think there is a white/cream one (could be yellow) as if it blows then it wont start! you can see if its blown by looking in the top of it (has a clear lid)
If I get out of work at a reasonable time tomorrow, I'll pop over if you like. We can both scratch our heads and take sharp intakes of breath together :D
That'd be cool Matt - don't suppose you have a dizzy cap/rotor arm I could borrow to see if that is the actual problem??:D
I'll PM you my number
Can you start the car now? Does it have RLTC?
My car started to cut out for no apparent reason, and Matt traced it to the RLTC fuse which caused this when it got hot. The standard one is (or maybe was, if they've changed it now) a peice of crap. He changed it, and no more problem....
