Muffleman Posted September 19, 2006 Share Posted September 19, 2006 Check out the engine bay of the silver Supra from this trader http://www.japaneseimportsltd.co.uk/GetDealer.do?did=20024&pageid=1 Hmmm, curious - certainly not a 3litre twin turbo as advertised ! Link to comment Share on other sites More sharing options...
jamesmark Posted September 19, 2006 Share Posted September 19, 2006 Its a mitsi engine, probably out of a 3000 GTO TT Link to comment Share on other sites More sharing options...
TLicense Posted September 19, 2006 Share Posted September 19, 2006 That's ermmm unique Link to comment Share on other sites More sharing options...
lockys96 Posted September 19, 2006 Share Posted September 19, 2006 ha, the guy bought it and knows nothing about cars. it looks similar to that of a fto? Link to comment Share on other sites More sharing options...
Scooter Posted September 19, 2006 Share Posted September 19, 2006 ....wonder if its 4wd (GTO)?! Link to comment Share on other sites More sharing options...
GeordieSteve Posted September 19, 2006 Share Posted September 19, 2006 Been on here before I believe. He's mixed up a pic of an FTO by accident iirc Link to comment Share on other sites More sharing options...
Ewen Posted September 19, 2006 Share Posted September 19, 2006 First cut off the affected part and attach a supporting spur. This involves temporarily supporting the fence and then digging a hole around the post about 60 cm square and 30 cm deep. Saw off the rotten part of the post once it is completely exposed and bolt on the concrete spur - 15 cm or 20 cm coach bolts are suitable. The straight face of the spur should be against the post. When it is in position, use a spirit level to check it is upright. Hardcore should then be packed around the bottom of the spur and the hole filled with a coarse concrete mix, finished at ground level with a slope to drain rainwater off. Link to comment Share on other sites More sharing options...
Gazboy Posted September 19, 2006 Share Posted September 19, 2006 Wahey! So they did make a V6 Supra lol!!! Link to comment Share on other sites More sharing options...
jamesmark Posted September 19, 2006 Share Posted September 19, 2006 First cut off the affected part and attach a supporting spur. This involves temporarily supporting the fence and then digging a hole around the post about 60 cm square and 30 cm deep. Saw off the rotten part of the post once it is completely exposed and bolt on the concrete spur - 15 cm or 20 cm coach bolts are suitable. The straight face of the spur should be against the post. When it is in position, use a spirit level to check it is upright. Hardcore should then be packed around the bottom of the spur and the hole filled with a coarse concrete mix, finished at ground level with a slope to drain rainwater off. Will make a start on Saturday!! Link to comment Share on other sites More sharing options...
RobSheffield Posted September 19, 2006 Share Posted September 19, 2006 Ewen, i just realised what all that meant Link to comment Share on other sites More sharing options...
Gazboy Posted September 19, 2006 Share Posted September 19, 2006 First cut off the affected part and attach a supporting spur. This involves temporarily supporting the fence and then digging a hole around the post about 60 cm square and 30 cm deep. Saw off the rotten part of the post once it is completely exposed and bolt on the concrete spur - 15 cm or 20 cm coach bolts are suitable. The straight face of the spur should be against the post. When it is in position, use a spirit level to check it is upright. Hardcore should then be packed around the bottom of the spur and the hole filled with a coarse concrete mix, finished at ground level with a slope to drain rainwater off. Fantastic, cheers! Link to comment Share on other sites More sharing options...
Tom Posted September 19, 2006 Share Posted September 19, 2006 Been on here before I believe. He's mixed up a pic of an FTO by accident iirc Yep, really people you should know what your engine bay looks like Link to comment Share on other sites More sharing options...
Muffleman Posted September 19, 2006 Author Share Posted September 19, 2006 First cut off the affected part and attach a supporting spur. This involves temporarily supporting the fence and then digging a hole around the post about 60 cm square and 30 cm deep. Saw off the rotten part of the post once it is completely exposed and bolt on the concrete spur - 15 cm or 20 cm coach bolts are suitable. The straight face of the spur should be against the post. When it is in position, use a spirit level to check it is upright. Hardcore should then be packed around the bottom of the spur and the hole filled with a coarse concrete mix, finished at ground level with a slope to drain rainwater off. Definitely too much time on your hands mate Link to comment Share on other sites More sharing options...
RobSheffield Posted September 19, 2006 Share Posted September 19, 2006 Matt, you gotta agree, its funny in itself Link to comment Share on other sites More sharing options...
Muffleman Posted September 19, 2006 Author Share Posted September 19, 2006 Yeah tis funny, and well done too Link to comment Share on other sites More sharing options...
Pixelfill Posted September 19, 2006 Share Posted September 19, 2006 Glad to see Ewen is on top form - took me a while to work out how all that related to this post Mike Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 19, 2006 Share Posted September 19, 2006 I went and looked at a Supra there, at the beginning of the year, and it was a real dog! bad panel gaps looked like a badly repaired accident to me, engine sounded dodgy as well, beware! Link to comment Share on other sites More sharing options...
