Why is it that lots of people on here don't understand the what OD does???
ardasaliah
: So Sorry to start this off but reading around the subject sooooo many people think the OD button is a magical switch that holds the revs longer/ make it go faster/ spreads 3 gears over the rev range. Increases the 0-60 times - etc etc- the list goes on and on and on. All it does is switch off 4 gear---- Thats it very very very simple.
Its not hard to work out.
Sorry to rant but every so often this comes up and I am very worried/intrigued that "knowledgeable enthusiast" find the concept of OD off complicated :rolleyes
Why would you turn of 4th gear? ...I'm one of those that doesn't understand the OD! :search:
if you are following a car around 55-60mph and you want to overtake, you can flick the o/d off to drop you down to 3rd before you pull out and accelerate (sp?) past the car, just like you would in a manual car. Otherwise, if you rely on kickdown then you're normally halfway over the wrong side of the road when the box drops a cog.
when i was a newbie i didnt know what it was for and im not ashamed to admit that having never been in an auto.
only the other week did i then realise that i had driven all the way from london to llanelli, after picking it up,with it off and was wondering why it wouldnt go above 120 mph lol:d
Rant justified mate! its cos people dont understand a gear box!
Exactly! Why do they call it overdrive - it's not an MGB:blink:
Overdrive can refer to two different things. An overdrive is a device which was commonly used on rear-wheel drive automobiles to allow the choice of an extra-high overall gear ratio for high speed cruising, thus saving fuel, at the cost of less torque.
It also refers to a combination of gearing inside a transmission or transaxle which results in the output speed being greater than the input speed. In the latter case, "overdrive" does not refer to a physically separate identifiable part/assembly.
The automatic transmission automatically shifts from OD to 3rd gear when more load is present. When less load is present, it shifts back to OD. Under certain conditions, e.g: driving uphill or towing a trailer, the transmission may "hunt" between OD and 3rd gear, shifting back and forth. In this case, switching it off can help the transmission to 'decide'. It may also be advantageous to switch it off if engine braking is desired, for example, driving downhill. For more details, check your owner's manual
http://en.wikipedia.org/wiki/Overdrive_%28mechanics%29
Mike
Good find that Mike. In our case, it's not a specific 'overdrive assembly'. Such a device would give a total of six effective gear ratios if we had one.
As I understand it anyway.
In our case it's just that it's an overdriven gear - the output speed is greater than the input speed.
Does it not also defeat the lock-up clutch on the torque converter?
When I turn OD on, I feel like get a slight increase in speed, which you get if the lock-up clutch made the speeds of the gearbox input shaft equal to the engine speed. With OD off I get a slight drop in speed, ike the gearbox is spinning slower, but not a whole gear's worth slower.
If you get my drift.
I get a similar thing with MANU. Revs rise very slightly when MANU is engaged.
Q. I have just bought an Auto MKIV. What are the three buttons for?
A. 1. Overdrive. Engages the fourth gear on the auto box. Actually reduces the pressure with the gearbox so that the RPMs fall and fuel economy is increased.
2. Has two Japanese letters next to button. Roughly translated these mean "Park Release". If the button is pressed the gear stick can be moved (at the same time) from the park position without depressing the brake pedal.
3. Has the word "MANU" on the button. Allows the driver to select "Power" or "Economy" mode. The only difference is in power mode the car will hold the first and second gears longer (to higher revs) and allow you to take off faster at the lights. Power mode will increase your fuel consumption.
Sorry, but this is incorrect. There is no "Power" or "Economy" mode.
The MANU button does make the transition between gears faster. The ETCS (throttle control) backs the throttle off between gear changes when under load. (Like at WOT) This is to make the gear change smoother. In MANU mode, this 'backing off' of the throttle is reduced. This can mean slightly harsher changes but faster.
As for MANU mode holding on to the gear to higher revs, this will be because it won't change up until you move the gear lever!!!
AND.....as for getting off faster at the lights in MANU mode, as stated by Need4Speed, if you've got it in anything other than 1st, you'll pull away in 2nd.....which ain't that fast. Try it and see.
Well, one out of three isn't bad. Where did you get that FAQ from?
1 - The gearbox pressures I thought were entirely mechanical. And anyway, reducing pressures wouldn't make the revs fall :blink: OD just stops you from going into 4th gear.
3 - MANU sticks you in a gear and leaves you there. You never go into 1st unless you select 1st, so it's not going to help you get away from the lights any faster. There is no power or economy mode, it's manual or automatic. The "holding the revs" thing is such an urban myth, especially as MANU mode you'll not change up until you tell it to anyway. The autobox will wind up to the redline if your foot is on the floor no matter what mode it's in - that's why it's an "auto" - no manual intervention required.
I feel an FAQ entry coming on...
-Ian
hehehe, I love these threads.
1) Overdrive is 4th gear, thats it pure and simple
2) MANU is manual control (with faster gear changes), thats it pure and simple
the only question I have is does anyone know why it won't let you use overdrive in MANU mode?
