JamieP Posted September 17, 2006 Share Posted September 17, 2006 Worthwhile mod?... do the stock ones break? or is it a case of these are lighter? many thanks jamie:) Quote Link to comment Share on other sites More sharing options...
LeeT Posted September 18, 2006 Share Posted September 18, 2006 Yes the stock ones do break but if mine ever does i'll just replace it with a OEM one again Quote Link to comment Share on other sites More sharing options...
JamieP Posted September 18, 2006 Author Share Posted September 18, 2006 does it not damage the engine then if it breaks? Quote Link to comment Share on other sites More sharing options...
Terminator Posted September 18, 2006 Share Posted September 18, 2006 The stock damper is fine on modified cars upto a certain level? I think Dude did post that he had noticed a number of older ones needing replacing now. Rapid deterioation will occur if heat is used to remove one that is going back on the car. AFAIK the most significant instant effect of failure is loss of power steering. I think there is usually some short time where odd sounds may be heard as failure is usually over a period of time, as the pulley moves out of alignment. An atermarket damper/pulley reduces the rotational mass at the crank. Some are rated for race use ie higher spec. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 18, 2006 Share Posted September 18, 2006 Change a crank damper at your peril. I would ALWAYS stay with stock. I have spent a LOT on my Skyline race engine, at least 25K in parts alone, it's got a new stock Nissan damper on it... Quote Link to comment Share on other sites More sharing options...
Daston Posted September 18, 2006 Share Posted September 18, 2006 The boost logic one is same size as stock. When the crank goes the biggest problem is the timing belt if that snaps then it will take out most of the pipes and intake. Mine started to squeal then it just dropped off 10 miles later (on my way to get it looked at) thankfuly the belt just slipped off the biggest loss is the water pump I think. Quote Link to comment Share on other sites More sharing options...
TLicense Posted September 18, 2006 Share Posted September 18, 2006 I think the biggest problem if the crank dampener goes, is the fact you've now got a lump of metal that was rotating at the same speed as the engine, not connected to anything, under the bonnet of your car. Quote Link to comment Share on other sites More sharing options...
Marco Posted September 18, 2006 Share Posted September 18, 2006 Mine broke. It had a big chunk missing! I'll post a pictures tonight when I'm at home. Quote Link to comment Share on other sites More sharing options...
JamieP Posted September 18, 2006 Author Share Posted September 18, 2006 Thanks guys.. ill buy a new stock one then. Quote Link to comment Share on other sites More sharing options...
LeeT Posted September 18, 2006 Share Posted September 18, 2006 Thanks guys.. ill buy a new stock one then. Let me know the price Jamie. Steve Manley will be your best bet Quote Link to comment Share on other sites More sharing options...
JamieP Posted September 18, 2006 Author Share Posted September 18, 2006 ok thanks mate;) Quote Link to comment Share on other sites More sharing options...
Ian C Posted September 18, 2006 Share Posted September 18, 2006 You normally get a loud squealing as the rubber seperates. Consider that your warning shot CW meant to add the reason why he uses a stock dampener Which is, I presume, durability and the crank balancing function. -Ian Quote Link to comment Share on other sites More sharing options...
Ian C Posted September 18, 2006 Share Posted September 18, 2006 http://www.mkivsupra.net/vbb/showthread.php?t=35945 For more info. -Ian Quote Link to comment Share on other sites More sharing options...
JamieP Posted September 18, 2006 Author Share Posted September 18, 2006 Thanks ian.. appreciated. Quote Link to comment Share on other sites More sharing options...
