1995 auto
2jzhead
i want to get the full speed out of it and not just use 2nd turbo i have been told if i put it in second, i am using 1st turbo then in drive it uses the second turbo or somthing like that
Nope the engine will still use both tubbies...
The black manu button, simply prevents it from changing gear. If you are in D and manual mode, it will start in a lower gear, but immediately change into D as soon as it can, and stay there.
Put it into M mode, and then you use L-2-D as the gears..
