need your help everyone
rovervi
I have pulled all my dash out and that was as easy as everyone said thanks for the advice.
Got my new kenwood headunit in the cage but the adaptor i have doesnt fit (arses sold me 86-93 version) and i need to know pretty quick what adaptor i need.
I also have loads of blown bulbs and have found the ones that fit but dont know if i need 2.4watt or 1.2watt (1.2 may not be bright enough and 2.4 may burn the front of the unit)
hope someone can help, its a Jspec if that makes a difference.
HEEEEEEEEEEEELLLLLLLPPPPPP PPPPPPPLLLLLEEEEEAAAAASSSSSSSSEEEEEEEEE lol
The connector that mrb mentioned has an iso plug on it this end goes in to your stereo (new one) the other end with the 2 plugs, look in to the dash area, to the left, tucked down the side you will see 2 white plugs connected to a loom, this is where the stock amp is plugged in, you need to unplug those 2 white plugs and add the adaptor you bought to that end, thats where they fit.
I have taken the loom off and i am left with these 2
This is the other that came out of the back of the stereo
This is the map of the adaptor harness pc2 - 17 - 4
So i cant see how they will fit
Give me a chance im finishing my porridge oats, i will be stripping the car down afterwards and can take some pictures then :D
ha ha sorry mate not rushing you was just seeing if anyone else knew to save you some work, enjoy the porridge oats lol get a brew in while your at it lol lol
Right i have done some photos for you, i hope it is clear, unless your stereo has a completely different connection type :( We shall see
Picture 1 - the 2 white connectors that were originally plugged in down the side of the transmission tunnel.
Picture 2 - pc2 - 17 - 4
picture 3 - pc2 - 17 - 4 plugged in to connectors from picture 2.
picture 4 - connector on back of stereo
picture 5 - pc2 - 17 - 4 plugged in to stereo.
Thanks for this mate
Mine is completely different to this i dont have those 2 plugs to plug into :( i have no idea
