2jzgte VVTI internals questions..
Guest lexispooled
Guest lexispooled
Has anyone tore down a vvti 2jzgte?
There is some debate here in the US about the vvti engines having thinner rods then the USDM supra TT 2jzgte..Just wondering why toyota would use different rods in the late model GTE engine..Here in the US VVTi gte engines are hard to come by and very rare, there have only been 2 different findings and both seemed to suggest the same..Also could the aristo vvti and supra vvti be different internally?
Also someone recently compared the internals to the IS300 2jzge internals and they appeared to to be the exact same, jus wondering how that could be since the GE engine is 10.5:1 compression and the GTE is 8.5:1..Was told even the part numbers cast into the pistons were the same, could it be a thicker headgasket? I wouldnt think that would be the only difference to drop compression from 10.5:1 to 8.5:1..
Hi
I've just checked the Toyota EPC(covers the VVTI aswell), the con-rods are the same in the VVTI as the ones in our UK spec car which are the same as your US car.
part no - 13201-46040
Just to confirm what Merckx said; I've rebuilt a VVTi TT engine and replaced some of the rods and they are exactly the same as non-VVTi TT rods.
I would guess that the GE has a larger volume combustion chamber (in the head of course)
Also someone recently compared the internals to the IS300 2JZ-GE internals and they appeared to to be the exact same......was told even the part numbers cast into the pistons were the same......
Part numbers or casting numbers? In the interest of economies of scale. I'd have thought it was quite possible that the N/A and TT pistons start as the same rough casting but are machined differently.
Guest lexispooled
I thought oil squirters were DEFINITELY not in the GE engine....
they are not, where did I say that?
I did have the squirters installed in my GE block few years back for lil more peice of mind..
Guest lexispooled
casting numbers, you are probably right though..
Guest lexispooled
I hope the oil pumps are the same, then. Oil squirters take a lot of oil out of the system.
tuners here have done fine using the GE pump with oil squirters installed, one tuner even recommended the GE one over the GTE oil pump..Could always mod the pump I suppose for increased oil flow, thats what many are doing now for big hp.
  • 9 years later...
The NA VVTi engines have different, weaker rods than the non-VVti's. I just wasn't sure if the same applied to TT engines :)
The VVTi NA has thinner rods than the non-VVTi NA.
The non-VVTi and VVTi turbo engines are no different to each other in that aspect though. :thumbs:
