Harnesses
chris aka fonz
The only safe way to mount them is using a proper harness bar. The seat belt points are too low down and could result in a serious spinal injury in a crash as your spine will compress. If you don't mount them and use them correctly harnesses can be more dangerous than the normal belts. You must keep the lap strap very tight to stop the shoulder straps pulling it up off your waist, and preferably use an anti-sub strap (crotch strap) which is designed to stop it pulling up.
