johnd-mkiv Posted September 11, 2006 Share Posted September 11, 2006 Just had an exedy twin plate fitted, to be honest its a right fooker to get the hang of, its all or nothing just wheel spun it reversing up my drive as it wont really pull away under 2.5k, I dread to think what its going to be like in the wet:blink: Not only that it rattles like a bastard, which is embarrasing at the lights Im just hoping it will wear in a bit and not be so aggressive? all in all £1300 down and not to happy Link to comment Share on other sites More sharing options...
JamieP Posted September 11, 2006 Share Posted September 11, 2006 Haha... i think the exeddy twin plate is loverly to drive with.... you wanna try a ORC 4plate, now that was a bitch of a clutch.. few days and you will get use to it;) Link to comment Share on other sites More sharing options...
LeeT Posted September 11, 2006 Share Posted September 11, 2006 You can buy a new slave rod from HKS which will help with the grabbing problem. I have one and think the HKS twin plate is great whereas others who havent had the slave rod say that it is unbearable. I raised my idle to 1100k to get rid of the rattling Link to comment Share on other sites More sharing options...
johnd-mkiv Posted September 11, 2006 Author Share Posted September 11, 2006 You can buy a new slave rod from HKS which will help with the grabbing problem. I have one and think the HKS twin plate is great whereas others who havent had the slave rod say that it is unbearable. I raised my idle to 1100k to get rid of the rattling Think drive it for a bit and if im still not happy with it ill go that route, how did you raise your rpm? cheers;) Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted September 11, 2006 Share Posted September 11, 2006 should be fun on wednesday then john ;-) Link to comment Share on other sites More sharing options...
Muffleman Posted September 11, 2006 Share Posted September 11, 2006 You can buy a new slave rod from HKS which will help with the grabbing problem. I have one and think the HKS twin plate is great whereas others who havent had the slave rod say that it is unbearable. I raised my idle to 1100k to get rid of the rattling Good to know mate, I have the HKS triple and it's like a switch ! Link to comment Share on other sites More sharing options...
Jonty Posted September 11, 2006 Share Posted September 11, 2006 I had the OS Giken fitted on my T78 and it drives really well. My old one was Exeddy twin plate and rattled alot. However my new one has slight rattle - it's not snatchy though. You can adjust the clutch usually and a bit of wear might help things. I know wot you mean at the lights - now you have them lookin at you:) Hope you get it sorted as its loads of dosh if you don't like it Jonathan Link to comment Share on other sites More sharing options...
johnd-mkiv Posted September 11, 2006 Author Share Posted September 11, 2006 Just took her out for a long run its def getting better the rattle quietens down over 1100rpm which is good, standing starts are a mssion though getting bad wheel hop guess ill need to loose some pressure from my tyres? how would you set up the shocks? hard or soft on the rear? I have tein super street fitted Link to comment Share on other sites More sharing options...
johnd-mkiv Posted September 11, 2006 Author Share Posted September 11, 2006 should be fun on wednesday then john ;-) Side ways is the new forwards it seems Link to comment Share on other sites More sharing options...
supra matt Posted September 11, 2006 Share Posted September 11, 2006 Just took her out for a long run its def getting better the rattle quietens down over 1100rpm which is good, standing starts are a mssion though getting bad wheel hop guess ill need to loose some pressure from my tyres? how would you set up the shocks? hard or soft on the rear? I have tein super street fitted set your rear shocks a touch softer mate will give a bit more give to it all . So should not spin up as much Link to comment Share on other sites More sharing options...
johnd-mkiv Posted September 11, 2006 Author Share Posted September 11, 2006 set your rear shocks a touch softer mate will give a bit more give to it all . So should not spin up as much ill give it a try cheers;) Link to comment Share on other sites More sharing options...
Wez Posted September 12, 2006 Share Posted September 12, 2006 I had the OS Giken fitted on my T78 and it drives really well. My old one was Exeddy twin plate and rattled alot. However my new one has slight rattle - it's not snatchy though. You can adjust the clutch usually and a bit of wear might help things. I know wot you mean at the lights - now you have them lookin at you:) Hope you get it sorted as its loads of dosh if you don't like it Jonathan I also have the OS Giken and once you get use to it its fine. Link to comment Share on other sites More sharing options...
