c0c4in3 Posted September 11, 2006 Share Posted September 11, 2006 Hi, Never did that before. I would like to get some advice before messing my car. I have two sensors. One for oil temp and the other one for oil pressure. Where and how do I install it. Do I need to make a new hole somewhere in the oiltank or can I just use some other holes that are already there. Sorry if this sounds dumb, but I only installed boost gauges so far. Thanks! Link to comment Share on other sites More sharing options...
Lebsteif Posted September 11, 2006 Share Posted September 11, 2006 The way i did it was putting the sensors in a sandwich plate wich goes between the engine and your oil filter. very easy installation. http://www.archanox.demon.nl/stri/11.JPG Link to comment Share on other sites More sharing options...
c0c4in3 Posted September 11, 2006 Author Share Posted September 11, 2006 Thanks, looks good. Where can I get that plate from? Thanks, Oliver Link to comment Share on other sites More sharing options...
Lebsteif Posted September 11, 2006 Share Posted September 11, 2006 Hi mate, I see your located in germany. You can buy a plate at: http://www.mkivsupra.net/vbb/forumdisplay.php?f=125 This shop is in Germany as well. Link to comment Share on other sites More sharing options...
Gee Posted September 11, 2006 Share Posted September 11, 2006 Can you have your gauges installed this way if you intend to run an oil cooler kit also? Link to comment Share on other sites More sharing options...
D3xt3r Posted September 11, 2006 Share Posted September 11, 2006 Yes but you will need a special takeoff plate then. Greddy, HKS and so on Oil Cooler Kits will come with everything needed. Link to comment Share on other sites More sharing options...
bignum Posted September 11, 2006 Share Posted September 11, 2006 The only problem with measuring oil pressure at the filter plate is it gives very high readings because the filter housing itself is a restricted area, i found the best place for your pressure sender is the lexus bolt mod, temperature is ok at the filter plate,imo. Link to comment Share on other sites More sharing options...
Hayixer Posted September 11, 2006 Share Posted September 11, 2006 Go on, whats the Lexus bolt mod Link to comment Share on other sites More sharing options...
paul mac Posted September 11, 2006 Share Posted September 11, 2006 the only problem with the lexus bolt mod (do a search) it is an absolute b*****D to do, if you are a novice this aint gonna be easy Link to comment Share on other sites More sharing options...
bignum Posted September 11, 2006 Share Posted September 11, 2006 the only problem with the lexus bolt mod (do a search) it is an absolute b*****D to do, if you are a novice this aint gonna be easy yes it is fiddly to be honest:D Link to comment Share on other sites More sharing options...
