Veilside throttle body, beware!!
Paul Whiffin
Anyone out there with a Veilside plenum/throttle body, I would recommend removing the 2 screws that hold your butterfly in place and applying some loctite. One of my screws fell out at Bruntingthorpe earlier in the year, I presume it went straight through my engine as its nowhere to be seen, got lucky there! It also made my throttle stick wide open which was a bit scary, at least it happened on the track I suppose. And while investigating a couple of problems with a customers Supra this had one of the screws loose which was making the butterfly stick a bit. So anyone with one of these get your loctite out!
Ta
