HKS FCD Setting no.
c0c4in3
  • 1 year later...
  • 8 months later...
setting it on 12 is just the same as removing it, it does sweet fa on setting 12.
The lower the setting the more it fools the car.
it works by taking the signal in from the actual pressure and then only sending a percentage of that signal out depending on the setting. Setting 12 send 100% and thesetting 11 a bit less and so on.
So the lower you go the less airflow the car will think its getting.
9 is obviously the setting that keeps the output figure below the factory set boost cut.
