c0c4in3 Posted September 9, 2006 Share Posted September 9, 2006 Hi there, I know, that the Greddy bcc is much better but I only have the HKS one. I knew the setting ages ago. But now I wanted to fit it but forget what setting I need for the Supra. Was it 6 or 9? THANKS! Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted September 10, 2006 Share Posted September 10, 2006 Channel 9 mate. Quote Link to comment Share on other sites More sharing options...
c0c4in3 Posted September 10, 2006 Author Share Posted September 10, 2006 Big thanks! Quote Link to comment Share on other sites More sharing options...
Markie Posted January 10, 2008 Share Posted January 10, 2008 Another one I have dug up Just wondering what problems would the HKS FCD cause if its on setting 12? Whats the difference in the settings? Quote Link to comment Share on other sites More sharing options...
Markie Posted January 17, 2008 Share Posted January 17, 2008 Any ideas boys on the above please? Quote Link to comment Share on other sites More sharing options...
Markie Posted October 8, 2008 Share Posted October 8, 2008 Checked. HKS FCD deffo on setting 12. What problem could this cause if supposed to be on setting 9? Quote Link to comment Share on other sites More sharing options...
miko_supra Posted October 9, 2008 Share Posted October 9, 2008 Can't remember if i checked mine when i installed it :S so im interested to know the answer to the above Quote Link to comment Share on other sites More sharing options...
sparkystav Posted October 9, 2008 Share Posted October 9, 2008 setting it on 12 is just the same as removing it, it does sweet fa on setting 12. The lower the setting the more it fools the car. it works by taking the signal in from the actual pressure and then only sending a percentage of that signal out depending on the setting. Setting 12 send 100% and thesetting 11 a bit less and so on. So the lower you go the less airflow the car will think its getting. 9 is obviously the setting that keeps the output figure below the factory set boost cut. Quote Link to comment Share on other sites More sharing options...
