Exeedt twin plate flywheel bolts to short?????????????????????
johnd-mkiv
I was told the non turbo flywheel bolts are longer and will sovle the problem? this has really pissed me off How can a company make a clutch and not sell the correct bolts with it
non turbo bolts should be shorter iirc. You are trying to fit a lightened flwheel which is usually thinner than stock so will require SHORTER bolts. As i said above, give Bijal a ring as he supplies these. Alternatively try Jamiep as i'm sure he had one fitted recently
Thats what I would have thought but he def said they are to short.
Got hold of a set of n/a bolts will see whats the score with these tomorrow, researching on other forums it seems they use celica flwheel bolts for these clutches.
Does any one know the length of a standard TT flywheel bolt???
