johnd-mkiv Posted September 8, 2006 Share Posted September 8, 2006 Got my car in the garage at the mo with the gearbox off, just about to put the new exedy twin plate on but the origional flywheel bolts are to short:( any one know the correct bolts for it and where they can be sourced?????????????? Link to comment Share on other sites More sharing options...
LeeT Posted September 8, 2006 Share Posted September 8, 2006 Too short?? they were too long with my HKS twin plate and i had to buy non turbo ones iirc. Give Bijal a ring, he'll be able to tell you Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted September 8, 2006 Share Posted September 8, 2006 I've got some sat on my front room floor, and they are smaller in lenght than the OEM ones. Link to comment Share on other sites More sharing options...
LeeT Posted September 8, 2006 Share Posted September 8, 2006 I've got some sat on my front room floor, and they are smaller in lenght than the OEM ones. Thats what i said wasn't it? Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted September 8, 2006 Share Posted September 8, 2006 Just confirming your statement.... Link to comment Share on other sites More sharing options...
johnd-mkiv Posted September 8, 2006 Author Share Posted September 8, 2006 I was told the non turbo flywheel bolts are longer and will sovle the problem? this has really pissed me off How can a company make a clutch and not sell the correct bolts with it Link to comment Share on other sites More sharing options...
LeeT Posted September 8, 2006 Share Posted September 8, 2006 I was told the non turbo flywheel bolts are longer and will sovle the problem? this has really pissed me off How can a company make a clutch and not sell the correct bolts with it non turbo bolts should be shorter iirc. You are trying to fit a lightened flwheel which is usually thinner than stock so will require SHORTER bolts. As i said above, give Bijal a ring as he supplies these. Alternatively try Jamiep as i'm sure he had one fitted recently Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 8, 2006 Share Posted September 8, 2006 If it needs the same length bolts as the HKS flywheels you can use MKIII Supra ones, from memory. Link to comment Share on other sites More sharing options...
johnd-mkiv Posted September 8, 2006 Author Share Posted September 8, 2006 non turbo bolts should be shorter iirc. You are trying to fit a lightened flwheel which is usually thinner than stock so will require SHORTER bolts. As i said above, give Bijal a ring as he supplies these. Alternatively try Jamiep as i'm sure he had one fitted recently Thats what I would have thought but he def said they are to short. Got hold of a set of n/a bolts will see whats the score with these tomorrow, researching on other forums it seems they use celica flwheel bolts for these clutches. Does any one know the length of a standard TT flywheel bolt??? Link to comment Share on other sites More sharing options...
johnd-mkiv Posted September 9, 2006 Author Share Posted September 9, 2006 All sorted now The N/A supra flywheel bolts done the job cheers damo for sorting them for me Link to comment Share on other sites More sharing options...
LeeT Posted September 9, 2006 Share Posted September 9, 2006 All sorted now The N/A supra flywheel bolts done the job cheers damo for sorting them for me the n/a bolts are SHORTER though iirc. Hope you used new ones as they are stretch bolts;) Link to comment Share on other sites More sharing options...
