Cat back ?
Tourniquet
What does Cat back mean ?
After a nur spec zaust and have the option of back box only or cat back. Am i right in thinking this means you loose the second cat only and then the back box goes on this ?
I take it no complete system includes a down pipe to loose the first cat ?
What's the bloody point in that then ? Either way you still have both cats just the Spec R gives you sonething extra to polish!
Cheers guys.
not really. the spec R is a straight pipe from the front of the can to the second cat, the spec S just bolts up to the two seperate sections that split from the rear of the second cat.
so the Spec R is less restrictive :)
