apexi temp gauges and pillar pod
supradibbs
as tittle water and oil temp mounted in a pillar trim its a pillar that fits over your exsiting trim and is very good quality both are in perfect condition heres the spec on the gauges
The APEXi EL System Meters symbolize a revolutionary movement in engine monitoring systems. Electro Luminescence (EL) technology allows the EL Gauge to glow in a light blue color for better visibility at night. All electronic meters feature real time 30 second needle playback mode, peak hold mode, user present warning feature and an optional output warning signal. Visual features also include hyper extended needle for easier reading, illuminated needle, high impact 60mm bezel, and stamped with the APEXi logo. Unlike other manufacturers that have seperate bulky sending units, all APEXi meters are self contained within the meter. We utilize only OEM type sensors for ultimate reliability. APEXi electronic series meters are available in boost, EGT, pressure and temperature. Also available is the EL series mechanical boost meters in PSI or KPA.
