Auto LSD
Jezz
Jezzybabes, do you know if this would be a straight swap with my facelift 96 non LSD diff? and is it a simple enough job to unbolt & replace with the new one?
i've read that this can transform the drive of the car dramatically & mine unfortunately doesn't have an LSD according to the VIN plate
As long as its auto yes, should bolt straight in. I can throw in the shafts too for good measure. It does transform the car if you ask me. Traction is way better. :)
cheers jezzybabes. i found this in an old thread though regarding the TRD LSDs:
TRD make 2 versions of the LSD to fit the 2 different diff cases used on the Supra.
41301-JA800 TRD LSD
This is for all pre-facelift Supras with factory LSD fitted.
41301-JS402 TRD LSD
This is for all facelift Supras. Also for pre-faclift Supras without factory LSD fitted
in all honesty i'm just considering this as a potential upgrade at the moment, but wanted to clarify whether this was an option
i've got a vibration problem that i want to get diagnosed & fixed before i do anything else to my wallet drainer Supra
