Help!!!
DannoSupra
Ive had the same problem as you mate exactly those symtems.
I changed all the coil pack connectors, plugs and checked all intercooler hoses and vacume pipes also reset the ecu.
But if you reset ecu remember it will take about 10 mins for it to learn itself again.
I went BPU on Saturday.Just started enjoying all the power and then suddenly had exactly the same symptoms as yours.Have a look at your intercooler piping.One of the connections on mine got loose and the pipe blew off.As soon as I connected it everything was fine again:d
