2 pot front brake calipars with ABS
Supra Baggers
Please enlighten me as to what a calipar with ABS is? Or do you mean its a j-spec car with ABS? If so I have a set of front calipers for a J-spec motor sat in my garage if needed dunno if they came off a motor with ABS or not :D You'll find alot of people have J-spec brakes knocking around somewhere from when they removed them to it UK spec brakes.
Thanks for the reply. Needed to fit j-spec car with ABS. I bought current calipars not realising the car had ABS. Thanks for the offer, but sounds like they are the same calipars as the ones already fitted. Cheers
I think you need to post pics up of what you actually have as ABS has no bearing on the caliper whatsoever
Yeah, that is true...
The ABS pumps sits inline with the brake pipe. I would therefor hazard a guess that the calipers are exactly the same, since the pads are the same...
