Map sensor for an N/A
DannyW
I have been told in the past that the bit you have circled is the MAP sensor but i'm no expert.
I was under the impression that a MAF is quite obvious to spot, normally a plastic box of some sort after the airbox with either a flap or an element of some kind inside to measure the air flow. On an N/A there seems to be a, pretty much, straight through pipe between the air box and inlet manifold.
Can an expert please clarify this?
  • 2 weeks later...
