Trig Posted September 3, 2006 Share Posted September 3, 2006 Dont post in this section often quick question... im in the process of changing my pads and discs (UK) but which one is left and which one is right? Or does it even matter?? Theres no markings on them apart from L on both of them. but theyre clearly not for the same side (i hope!) http://img70.imageshack.us/img70/602/pict0013ss1.jpg Will prob be along later to ask about the pads too! Link to comment Share on other sites More sharing options...
Trig Posted September 3, 2006 Author Share Posted September 3, 2006 Im inclined to go with left one is left and right on is right?? Link to comment Share on other sites More sharing options...
Pig Posted September 3, 2006 Share Posted September 3, 2006 hmmm, im not sure. i would say the one on the left is the left one. thats a random guess though. search for a touring car or something, look at the disks and all will be clear! Link to comment Share on other sites More sharing options...
Trig Posted September 3, 2006 Author Share Posted September 3, 2006 edit: got the pads out now got to hope they all go back Link to comment Share on other sites More sharing options...
Trig Posted September 3, 2006 Author Share Posted September 3, 2006 Were getting somewhere! http://img330.imageshack.us/img330/3945/pict0015fn9.jpg Anyone know if i have to mount these on the new pads or are they just part of the old ones?? http://img330.imageshack.us/img330/4617/pict0016ze3.jpg And will i need to bleed the brakes?? Link to comment Share on other sites More sharing options...
Scooter Posted September 3, 2006 Share Posted September 3, 2006 Were getting somewhere! 1) Anyone know if i have to mount these on the new pads or are they just part of the old ones?? 2) And will i need to bleed the brakes?? 1) yes mount them and 2) not unless you've removed the pipe from the calipers (i assume you just hung them out of the way when fitting the disks) Link to comment Share on other sites More sharing options...
SimonB Posted September 3, 2006 Share Posted September 3, 2006 Those are the anti-squeel shims. You are supposed to use new ones, the old ones can get corroded and gunged up and if they are you will get spongy brakes. In any case the brakes feel much better without them so I would leave them off. Link to comment Share on other sites More sharing options...
Pig Posted September 3, 2006 Share Posted September 3, 2006 dont leave them off the brakes will make LOADS of noise! Link to comment Share on other sites More sharing options...
SimonB Posted September 3, 2006 Share Posted September 3, 2006 dont leave them off the brakes will make LOADS of noise! Mine make no noise whatsoever, and I haven't had them on for 4 years! Link to comment Share on other sites More sharing options...
Trig Posted September 3, 2006 Author Share Posted September 3, 2006 right ive mounted them and ill see what happens cheers for your help fellas. will let you know if they work or not (the brakes that is) Link to comment Share on other sites More sharing options...
Trig Posted September 3, 2006 Author Share Posted September 3, 2006 PS little tip. paint your calipers after you have replaced warped discs. need to do mijne again now!! Link to comment Share on other sites More sharing options...
Trig Posted September 3, 2006 Author Share Posted September 3, 2006 Now i cant get one of the caliper mount nuts off!! doh!! Link to comment Share on other sites More sharing options...
Trig Posted September 3, 2006 Author Share Posted September 3, 2006 think i need a breaker bar but havent got one to hand Link to comment Share on other sites More sharing options...
SimonB Posted September 3, 2006 Share Posted September 3, 2006 One of mine was a right PITA last time. Halfords do a nice big 18 inch breaker bar. Link to comment Share on other sites More sharing options...
Trig Posted September 3, 2006 Author Share Posted September 3, 2006 nice. do you know how much they are?? Link to comment Share on other sites More sharing options...
SimonB Posted September 3, 2006 Share Posted September 3, 2006 Can't remember, not cheap but not too bad and nice quality too. Sometimes difficult to get one in there wihout a lift though. I've resorted to jacking up the end of a wrench with a spare jack before too. Link to comment Share on other sites More sharing options...
Bob Posted September 3, 2006 Share Posted September 3, 2006 The groove on the discs doesn't matter which way it goes, you need to look at the venting inside the disc to check rotation - should be angled pointing clockwise, so the heat is expelled as it turns. Link to comment Share on other sites More sharing options...
Mike M Posted September 3, 2006 Share Posted September 3, 2006 A ring spanner on the end of the socket wrench can also work in emergencies if you dont have a breaker bar to hand. Link to comment Share on other sites More sharing options...
