DArby Posted April 4, 2002 Share Posted April 4, 2002 Can someone give me the Toyota part numbers for UK Spec brakes - front & rear, just picked them up from the local Toyota Garage, together with Lexus sets, one set looks suspisiously small.... Dean.. Link to comment Share on other sites More sharing options...
Guest Supragirl Posted April 4, 2002 Share Posted April 4, 2002 Dean, Just had a look on the CD...now I think I have got this right.. Front pads only 04465-14080 Rear pads only 04466-30030 If they differ to what you have got, perhaps Phil or Martin could confirm the above codes. Link to comment Share on other sites More sharing options...
Phil Wall Posted April 4, 2002 Share Posted April 4, 2002 Dean if you check the Great UK brake buy - thread the part nos are listed their. Link to comment Share on other sites More sharing options...
DArby Posted April 4, 2002 Author Share Posted April 4, 2002 With the greatest respect M (is it ok to abbreviate your name without getting in trouble around here ) I hope you're wrong, as i've not got any of those numbers on my invoice.... They start 04466 & 04465 but end 30050 & 14040 Dean.. Link to comment Share on other sites More sharing options...
Guest Supragirl Posted April 4, 2002 Share Posted April 4, 2002 Dean the code 04466 14040 is the same as in the great uk brake buy but I believe that the other code was 04465 14150 Martin will be back soon, I will get him to check the numbers for you. And yes Dean you can abbreviate my name to M or Em Link to comment Share on other sites More sharing options...
Guest Supragirl Posted April 4, 2002 Share Posted April 4, 2002 found out why my codes where different.....I seemed to be using the JAP side of the system Dean would you like a free EPCD? UK version of course.. I have a spare copy here that you can have if you want. Just let me know Em Link to comment Share on other sites More sharing options...
DArby Posted April 4, 2002 Author Share Posted April 4, 2002 M. Oh yes please, that would be great. I'll mail you my address. Thanks Dean. Link to comment Share on other sites More sharing options...
Guest Martin F Posted April 4, 2002 Share Posted April 4, 2002 Well the EPCD is not actually too helpful here, as it doesn't seem to list an exact part number for just the brake pad. But what i do have is :- Front Brake Pad & Shim Kit 04491-14331 Pad Only 04465 - XXXXX Rear Brakes Pad & Shim Kit 04492-14161 Pad Only 04466 - XXXXX Best thing would be if somebody has a receipt for a set from Toyota. Maybe we should add this info to the site somehow. Link to comment Share on other sites More sharing options...
Guest Martin F Posted April 4, 2002 Share Posted April 4, 2002 According to Toyotaguys in the US part numbers are :- Front - 04465-14150 Rear - 04466-14040 Link to comment Share on other sites More sharing options...
mrboost Posted April 5, 2002 Share Posted April 5, 2002 can I have a cd too! I will pay Cheers Martin Link to comment Share on other sites More sharing options...
Guest Martin F Posted April 5, 2002 Share Posted April 5, 2002 No problem will give you a shout when they are burnt. Link to comment Share on other sites More sharing options...
THOR Racing Posted April 5, 2002 Share Posted April 5, 2002 I wouldn't mind a copy of the latest CD's (I've got the older ones) Are these the lastest ones that Chris first mentioned? Reagrds Pete Link to comment Share on other sites More sharing options...
Phil Wall Posted April 5, 2002 Share Posted April 5, 2002 I don't know which version I have, but I can look up Facelift parts. Link to comment Share on other sites More sharing options...
DArby Posted April 5, 2002 Author Share Posted April 5, 2002 So i think i probably have the correct sets... What have a read about using copper grease ?? when fitting them - whats it for, what does it do ?? Dean.. Link to comment Share on other sites More sharing options...
Guest Martin F Posted April 5, 2002 Share Posted April 5, 2002 Quote: from TRL Performance on 10:21 am on April 5, 2002[br]I wouldn't mind a copy of the latest CD's (I've got the older ones) Are these the lastest ones that Chris first mentioned? Reagrds Pete Nope these are the older one's about '96 i think. Link to comment Share on other sites More sharing options...
Phil Wall Posted April 5, 2002 Share Posted April 5, 2002 If you put it on the back of the pads it is said to help reduce squeal. If you put it on the front of the pads you don't stop (sorry). (Edited by Phil Wall at 10:40 am on April 5, 2002) Link to comment Share on other sites More sharing options...
