Advice please age and kms
Golddigga
Guys and Girls,
I am possibly going to view a '93 L plate N/A this weekend.
The guy says that it has done 129,000kms and that the speedo is still in Km per hr? Somebody else has told me that they all need to be converted when they come into the country is this true? Is there anybody out there still running kms?
Also as the '93 is a relatively early model is there any major problems I should look out for? Even with 80,000 miles on the clock I have been told that the engine should still be quite bulletproof? Any view?
I want to take the plunge and get an N/A but don't want to be a pile of shite :notwork:
Your views please!
i have the conversion gismo added.
it just makes the car now read in mph, and clock up in miles ontop of the current km's on the clock.
bugger
My car is just about to go over 50,000km... about 30,000miles
is there anywhere that will convert my odo to read the right miles?
re: speedo and odometer conversion:
found this site, which shows you the steps to do the conversion:
http://homepage.ntlworld.com/peter.betts/supra/TechTips/speedo.htm
it may be of some use. sorry, if i should not have posted this link, as i have no idea who peter betts is. so feel free to remove it if there is a problem.
i remembered this site from when i was looking at Supra's last year
edited: i have no idea if this procedure will work, so am only posting the link to it.
i did ask about having the odo converted to true UK mileage, but was told it needs to be completely reset, and then wound up to the correct figure from the start, which can take a day or two.
so i left it at the converted option that was already done
Jamie, your car has not travelled 50,000 kms. :D
More like 49,000 .
The other 1000 was wheel spin I suspect:Pling:
I now drive in reverse to keep my kilometerage down :)
