tDR Posted March 18, 2004 Share Posted March 18, 2004 My Supe started leaking like a fountain, turns out it's the oil pressure switch after having a good look. I've ordered the part from Toyota which was £18.51 + VAT and am going to be changing it at the weekend. It looks a right b*stard of a job as the power steering pump and air con condenser are in the way. Anyone got tips / diagrams etc. on how to change it over quickly and easily? Do I really have to remove the above as I suspect to change the oil pressure switch? TIA, Brian. Link to comment Share on other sites More sharing options...
richardharmon Posted March 19, 2004 Share Posted March 19, 2004 Yes, afraid so! I had to change mine not too long back. Best thing to do is to get stuck in. When I changed mine, I found that Toyota had altered the design of the new switch and you need a smaller socket for the new one, had to go out and buy another long reach socket. Before you remove the AC and power steering pump, make a note of the path the serpentine belt takes around the pulleys, I didn’t and had to work it out afterwards. The easiest thing to do is just take all the mounting bolts (and one nut if I remember) off both pumps and just move them out of the way, no need to disconnect hoses or anything. After moving the pumps you should be able to get to the switch from the top. I looked at it for ages before deciding it was just going to be easier to take these bits off. I found it could be a bit of a sod lining up the bolt holes afterwards, thread all the bolts in loosely before tightening any of them, I found that if you tighten one before putting another one in they don’t line up correctly. Didn’t take too long when I got stuck in, pretty easy job really I would say. Link to comment Share on other sites More sharing options...
tDR Posted March 19, 2004 Author Share Posted March 19, 2004 Cheers Richard, That's just the advice I was looking for Roughly how long did the job take you? Seems like a small weakness of the mkiv supra, oil pressure switch going seems fairly common now. At least Toyota saw fit to redesign the switch. There's also a seperate part no. for the VVTi engines so they must have accepted it as a weakness. Link to comment Share on other sites More sharing options...
Andy Blyth Posted December 30, 2008 Share Posted December 30, 2008 I'm about to start this job myself this afternoon. I picked up my new pressure switch this morning and was surprised to see that it does not come with a gasket. After some searching and reading am I correct in thinking that it does not need any o-ring / dowty seal / PTFE tape? Link to comment Share on other sites More sharing options...
Pig Posted December 30, 2008 Share Posted December 30, 2008 Sorry to kick you in the bollocks while your down but please expect things like this to happen your car if you keep trying to keep up with us single boys Link to comment Share on other sites More sharing options...
Scott Posted December 30, 2008 Share Posted December 30, 2008 Sorry to kick you in the bollocks while your down but please expect things like this to happen your car if you keep trying to keep up with us single boys 11.8 1/4? Keeping up you say Link to comment Share on other sites More sharing options...
Scooter Posted December 30, 2008 Share Posted December 30, 2008 Just in case you don't have one the newer switch requires a deep 24mm socket (old style were 27mm - as you say it "shouldn't" be that style currently on your facelift) Link to comment Share on other sites More sharing options...
Pig Posted December 30, 2008 Share Posted December 30, 2008 11.8 1/4? Keeping up you say Ill never live it down Link to comment Share on other sites More sharing options...
Andy Blyth Posted December 30, 2008 Share Posted December 30, 2008 Just in case you don't have one the newer switch requires a deep 24mm socket (old style were 27mm - as you say it "shouldn't" be that style currently on your facelift) Cheers Scooter, thanks to a post of yours from years ago I was all prepared for the job. In the end I referred to the service manual which does not mention any sealant / gasket. I have just used a drop of threadlock and torqued the new sensor to 14Nm. Took it out for a long drive and there's no oil leaking any more! (now THERE's some famous last words!) Link to comment Share on other sites More sharing options...
tDR Posted December 31, 2008 Author Share Posted December 31, 2008 Sorry to kick you in the bollocks while your down but please expect things like this to happen your car if you keep trying to keep up with us single boys You do realise this was a thread I started nearly 5 YEARS AGO for my 2nd Supra rather than my current 4th Supra?!? Keep up indeed Mr. slow single boy. That's why you're talking of selling isn't it, you now feel down and depressed after the realisation sunk in you'd gone about things all wrong. Don't worry, we're here for you - just call the Samaritans on 0800 115 115 115 or alternatively email us about your problems on [email protected] Link to comment Share on other sites More sharing options...
Pig Posted December 31, 2008 Share Posted December 31, 2008 You do realise this was a thread I started nearly 5 YEARS AGO for my 2nd Supra rather than my current 4th Supra?!? Keep up indeed Mr. slow single boy. That's why you're talking of selling isn't it, you now feel down and depressed after the realisation sunk in you'd gone about things all wrong. Don't worry, we're here for you - just call the Samaritans on 0800 115 115 115 or alternatively email us about your problems on [email protected] :rlol: I could never have predicted such a reply! P.S - Your mean Link to comment Share on other sites More sharing options...
tDR Posted December 31, 2008 Author Share Posted December 31, 2008 :rlol: I could never have predicted such a reply! P.S - Your mean Always a pleasure P.S - www.youre.co.uk Link to comment Share on other sites More sharing options...
Pig Posted December 31, 2008 Share Posted December 31, 2008 Always a pleasure P.S - www.youre.co.uk Doh Link to comment Share on other sites More sharing options...
Jellybean Posted October 25, 2018 Share Posted October 25, 2018 What is the process to reomve the switch? do you need to remove the power steering pump? Link to comment Share on other sites More sharing options...
Scooter Posted October 25, 2018 Share Posted October 25, 2018 You need to move the air con compressor, couple of bolts and one stud. You don't have to degas Link to comment Share on other sites More sharing options...
