Ported Manifold?
michael
My turbos are being replaced at the end of next week, nothing exotic, just late spec standard UK ones (although they might not be 100% normal).
Is there any benefit to be gained from me porting my turbo manifold like this?
Is there an art to it or can I just dremel away? ;)
You may need something a bit beefier than a dremel. I was out doing a bit of tidying up on my cast HKS manifold tonight and the cast iron was wearing down my grinding stones (big ones in a drill) faster than the stones were wearing down the manifold :D
From my discussions with a retired tuner, who did mainly head work and manifold matching work for competition engines from across the globe, there is a real art to this and should not be undertaken lightly. If you are just doing light smoothing/ polishing the you should not have a problem, if you have the right tools. If you are trying to make significant increases to flow you have to be extremely careful, if you create a thin spot you could cause a failure in the manifold. JMHO
I was really just wondering if it was worth doing while the manifold was off - I lack the tools and skills to do it and I suspect the mechanic doing the work won't have the time to do it for me but thought it might be a nice idea :)
Maybe we can do a bit of light polishing or something as a compromise.
The guy in question, did work on some of my cars, not the MKIV. His workshop was more like an art gallery. The precession of his work was incredible. I use to get him to balance the cylinders to get equal compression by equalising the volumes.
If you can smooth the surface while the pipes are off it won’t do any harm , but it is not worth pulling the car apart for, the gains will be minimal.
