Pig Posted August 28, 2006 Share Posted August 28, 2006 Im about to go and take off the O2 sensor on my uk spec to clean it. I have searched and just want to check im right. I simply un bolt the O2 sensor from the decat pipe follow the wire back and un clip it. Leave it in lemon juice over night to clean it. Regard the idle control valve, here is the pic i have of it. Is it just a case up take off and clean? What do i clean it with? http://www.mkivsupra.net/vbb/attachment.php?attachmentid=13939&d=1112558977 Quote Link to comment Share on other sites More sharing options...
supra matt Posted August 28, 2006 Share Posted August 28, 2006 a spot of carb cleaner mate . Quote Link to comment Share on other sites More sharing options...
Robert Posted August 28, 2006 Share Posted August 28, 2006 yeah there are 3 bolts, and two coolant pipes underneath. Don't lose the washer in between the IACV and intake manifold, I used brake cleaner to clean it out. Quote Link to comment Share on other sites More sharing options...
Pig Posted August 28, 2006 Author Share Posted August 28, 2006 Off to halfrauds to go and get some brake cleaner then! Quote Link to comment Share on other sites More sharing options...
bondango Posted August 28, 2006 Share Posted August 28, 2006 Carb cleaner or WD40, just to loosen any crap that has gunged up inside it. Some people just remove the pipe which runs to the inlet and spray little amounts inside while the engine is running. But better its to remove it because a visual check is always a good idea. I think steve stripped his down to find the diaphram was cracked which wouldnt off hepled his running lean problems. Quote Link to comment Share on other sites More sharing options...
terribleturner Posted August 28, 2006 Share Posted August 28, 2006 Jon whats wrong with the ICV?? Im just thinking you could always give it a quick test once it's off. Quote Link to comment Share on other sites More sharing options...
Pig Posted August 28, 2006 Author Share Posted August 28, 2006 The car wont idle properly. Its really lumpy and sometimes even cuts out! Im not sure what to do to sort it. I have just taken the O2 sensor out and i look to already be cleaned. (pheonix prob did it when doing the single conversion) However its not plugged into anything. and the end of the plug is also melted. I just plugged it in to where i think it goes (by the front of the engine, but it made no difference) Any ideas for next moves?? Quote Link to comment Share on other sites More sharing options...
Pig Posted August 28, 2006 Author Share Posted August 28, 2006 Oh and there is also a plug by the ICV which is not plugged in! Quote Link to comment Share on other sites More sharing options...
Pig Posted August 28, 2006 Author Share Posted August 28, 2006 Cleaned the ICV, idle is better. Not wanting to stall now. Still a little lumpy though, sitting just below 1K and bumping up and down. Any idea's? Also any idea's why my O2 sensor didnt need to be plugged in?? Quote Link to comment Share on other sites More sharing options...
bondango Posted August 28, 2006 Share Posted August 28, 2006 As you've cleaned it out, reset the ECU so it can relearn the Idle control now the valve has been cleaned out. If afater a few hoirs of driving its the same, you may need to check the Throttle position sensor. RE: o2 sensor not being plugged in. Is the car running a wideband o2? some you can configure an output to mimic the factory 1volt o2 signal to the ECU hence doing away with the stock sensor. Usually an unplugged o2 sensor will throw a code 21 Marty Quote Link to comment Share on other sites More sharing options...
Nic Posted August 28, 2006 Share Posted August 28, 2006 Are you sure it was the O2 sensor and not the cat temp sensor that was unplugged? Usually when cats get removed the temp sensor is tied up out of the way. Quote Link to comment Share on other sites More sharing options...
Pig Posted August 28, 2006 Author Share Posted August 28, 2006 Ahhh, that it could be. It was right at the top. Anyone got a pic of an O2 sensor? This is into the decat pipe. If its useless why would the decat pipe have a hole for it? Quote Link to comment Share on other sites More sharing options...
terribleturner Posted August 29, 2006 Share Posted August 29, 2006 Melted plug?? Plugs not in?? Have you got a close up picture Jon?? The O2 sensor you removed, did it have small holes in it and about 10-15mm thick?? Or was it about 5mm thin?? O2 Sensor http://alflash.narod.ru/O2/388.jpg Not a Toyota one, but this is roughly the size of a Cat Temp Sensor. http://www.microlabinfo.com/images/products/103.gif Quote Link to comment Share on other sites More sharing options...
