Removing front lights!!
kornboy119
It has just rained and I have found that my right hand side front light has misted up. I have removed the light, but I can't seem to be able to remove the glass, I don’t want to force it in case I break it. Could anyone please tell me what I could do, to get the glass off or to get rid of the mist?:rolleyes:
Cheers
Dan
Dont take off the glass!!
remove the main beam bulb.. and get a hairdryer wich will dry it out inside.. do this till it is totally dry, then replace the bulb.. if it continues to mist up inside you may need to re-seal it.
