razza Posted August 25, 2006 Share Posted August 25, 2006 Just fitted the restrictor ring on the exhaust, does the ring replace the smaller ring already in the exhaust (looks kind of like a gasket), or does it go in as well as? This was in between the first de-cat pipe and the middle section of exhaust, not the top end of the de-cat pipe by the engine. If it goes in as well as can someone let me know which way the lip round the ring should face, i.e. forwards or back as it fell out when I removed the bolts and didn't catch sight of which way round it was. cheers Link to comment Share on other sites More sharing options...
merckx Posted August 25, 2006 Share Posted August 25, 2006 I'm not sure which way the gasket goes - I cannot remember, you can dispense with it. Just use some exhaust assembly paste between the joints to give you a good seal. Link to comment Share on other sites More sharing options...
razza Posted August 26, 2006 Author Share Posted August 26, 2006 where's a good place to get some of this paste? will halfords do it? Link to comment Share on other sites More sharing options...
merckx Posted August 26, 2006 Share Posted August 26, 2006 You might have got some by now, I get mine from my local car accessory shop. Not sure about Halfords. Link to comment Share on other sites More sharing options...
razza Posted August 26, 2006 Author Share Posted August 26, 2006 Halfords did the job, just need to find a quiet strip of road to test out the boost now. Do I need to reset the boost controller now it's running at different levels, i.e. has restriction on it in the form of the ring and is now fully decatted? Link to comment Share on other sites More sharing options...
