TT Clutch
guye_d
Hello there
The Stock clutch would be more than man enough unless you have plans for a single conversion.
How many miles has your car done if it is 60 k + i would do the flywheel at the same time.?
Also change the gearbox fluid (V160 only) and while in the air the diff oil as well.
Check this post by me for part numbers:
CLICK ME
The search button is your friend ;)
  • 2 years later...
i have recently installed a centreforce duel friction clutch as my brother has 1 installed in his single and so does uk rich, im running bpu also and have found this to be very simular to original, as in pedal feels the same and i easy to drive once worn in 1000 miles or so, these are inported from america and is about £500 - 550 at the moment due to sterling being crap. But this clutch is good for 600 horse and same torque.
I have oder numbers and contact information here for centreforce if you wish to contact them.
http://www.dynamicturbo.com/products/drive-train/clutches/centerforce-dual-friction.html
its the 32nd down, number is DF510150, i have done drag but mostly trackdays and drfiting with this and has never let me down, my brother is running 500 - 550bhp and has had it fitted for about 2 years with no probs, he use's his car for trackdays also.
Cheers for that :) Does the flywheel rattle on this kit at idle?
This kit only include's pressure plate and clutch plate, NOT flywheel, if your flywheel rattles now then yes it will, but if you flywheel is ok then it should make diffrance at all.
Mine rattles when i turn the engine off and slightly in reverse but thats it.
