Daston Posted August 23, 2006 Share Posted August 23, 2006 Hi guys As many of you know my turbo dosn't clear my distributor without changing/modding my manifold so I thought the easy thing to do is get shot of it and get one with a smaller intake. I am open to offers however postage isn't going to be cheap (dont mind meeting people half way within reason). Ok so about the turbo I bought this from XS-Power in the states and it has only been rested on my manifold when testing the fitting the full spec of the turbo is as follows (hope you guys understand this cause I dont ) T04"P" Turbo Super T61 Turbo MODEL ST1 T4 FOOTPRINT .68T COMPRESSOR HOUSING .84 A/R TURBINE HOUSING 4" INLET SUPER HYBRID T61 SPECS Turbine Wheel: Exducer 2.54" Mayor 2.89" Compressor Wheel Super TO4E: Exducer 2.40" Mayor 3.58" Turbine Housing .84 Divided Flange Compressor Housing .70 4" Inlet I am willing to swap it for an Emanage or Apexi AFC or even a genuine HKS SSQV BOV or Greddy RS BOV If you need anymore info I will try to find out for ya Link to comment Share on other sites More sharing options...
JustGav Posted August 23, 2006 Share Posted August 23, 2006 Why not rotate the snail and put a 90 degree hard bend on the snail output which can then route to the intercooler? Link to comment Share on other sites More sharing options...
Daston Posted August 23, 2006 Author Share Posted August 23, 2006 its the intake thats the problem as I cant get the intake pipe on there as the distributor is in the way Link to comment Share on other sites More sharing options...
Bob Posted August 23, 2006 Share Posted August 23, 2006 Couldn't you swap the distributor with one of those electrical ignition thingymabobs that Demon Tweeks sells? :edit: Never mind, my brains not working properly today. Link to comment Share on other sites More sharing options...
bromy Posted August 23, 2006 Share Posted August 23, 2006 I dont think its your turbo that is the problem, if you look at that second to last piccie even if you have a 3" inlet it will only bring clearance in by 12.7mm on the side of the dizzy and still looks if it will catch, are you sure the manifold you got is not for a vvti?, I would be tempted to weld a plate onto the manifold mount where the turbo mounts to rotate it slightly as the 3" inlet is very weedy and looks crap wish I had gone for the 4" option from boostlogic Link to comment Share on other sites More sharing options...
Daston Posted August 23, 2006 Author Share Posted August 23, 2006 If I got a new T4 plate welded on at an angle I would need a new downpipe any idea how much one of these would cost? Link to comment Share on other sites More sharing options...
Alex Posted August 23, 2006 Share Posted August 23, 2006 Move the Dizzy? Link to comment Share on other sites More sharing options...
Daston Posted August 23, 2006 Author Share Posted August 23, 2006 can that be done? I have heard the US guys getting rid of it but surly that cant be cheap (not that I am cutting corners but I do have a budget) Link to comment Share on other sites More sharing options...
Terminator Posted August 23, 2006 Share Posted August 23, 2006 Looks like it is the metal sheild causing the most problems. You may be able to cut and roll the shield and get a custom made silicon pipe to slightly bend past the distributor. SFS Performance will make anything, but they are 9-10 weeks on back order, due to a huge overseas demand. Good prices too. http://www.sfsperformance.co.uk/ Link to comment Share on other sites More sharing options...
Terminator Posted August 23, 2006 Share Posted August 23, 2006 Looking more closely at the dizzy, I am sure more space could be gained by ditching the clips onthe leads. You could always mini tie wrap them to they can't come off. With a combination of that and a shield modification and a custom bend, I think you would be sorted. We had to have several custom hoses made up for the Skyline/200SX project. We also used a few parts from other makes of car. Rover Toyota and Volvo. Link to comment Share on other sites More sharing options...
Thorin Posted August 23, 2006 Share Posted August 23, 2006 Easier to make up a bracket and move the dizzy surely? Link to comment Share on other sites More sharing options...
Daston Posted August 23, 2006 Author Share Posted August 23, 2006 Cheers for the ideas guys I will talk to my motor electrician manager (aka Dad) and see what we can do. Any good ideas on where it can go or is there any companies that make smaller connectors? Link to comment Share on other sites More sharing options...
Lucifer Posted August 23, 2006 Share Posted August 23, 2006 We can make that fit. Link to comment Share on other sites More sharing options...
RedM Posted August 23, 2006 Share Posted August 23, 2006 Sorry, but WTF is a dizzy? Link to comment Share on other sites More sharing options...
Class One Posted August 23, 2006 Share Posted August 23, 2006 Sorry, but WTF is a dizzy? distributor. (easier on the tongue.) Link to comment Share on other sites More sharing options...
RedM Posted August 23, 2006 Share Posted August 23, 2006 Obvious I guess, but really! A dizzy!! Link to comment Share on other sites More sharing options...
bromy Posted August 23, 2006 Share Posted August 23, 2006 Easier to make up a bracket and move the dizzy surely? No can do it runs off the exhaust cam, coil packs is the way to go I eventually want to run these, igniter, Mk3 cam position sensor, wiring, possibly some gizmo to make spark stronger (DLI?) Link to comment Share on other sites More sharing options...
Lucifer Posted August 23, 2006 Share Posted August 23, 2006 No can do it runs off the exhaust cam, coil packs is the way to go I eventually want to run these, igniter, Mk3 cam position sensor, wiring, possibly some gizmo to make spark stronger (DLI?) Dont need to Brom, just a TT oil pump and you can machine the head for the sensor. Link to comment Share on other sites More sharing options...
Daston Posted August 23, 2006 Author Share Posted August 23, 2006 Cheers Martin well guys thanks for the help my little turbo is staying shall i give it a name? Link to comment Share on other sites More sharing options...
Lucifer Posted August 23, 2006 Share Posted August 23, 2006 How about Spook Link to comment Share on other sites More sharing options...
Terminator Posted August 24, 2006 Share Posted August 24, 2006 All good ideas, just take the simple option- hose. Call it Arse - as in tight. Ill get my coat. Link to comment Share on other sites More sharing options...
Gazzawu Posted August 24, 2006 Share Posted August 24, 2006 drop mark messina an email [email protected] Hes the dealer of xspower in clubna-t. He sells the flange which u weld on to clear the dizzy in the xspower kits. Gary Link to comment Share on other sites More sharing options...
