TrickTT Posted August 22, 2006 Share Posted August 22, 2006 The 2 hard lines that come from the autobox and run forward to the oil cooler, one stops just below the alternator pulley and the other one runs across the front of the engine and stops under the air-con pulley. Can anyone tell me which is the feed and which is the return pipe? Thanks Link to comment Share on other sites More sharing options...
JustGav Posted August 22, 2006 Share Posted August 22, 2006 Make sure you get them right... I pulled them off in order to flush the system completely and ended up putting the wrong one in the 5l bottle of new ATF... Looked somewhat silly when I rolled out from underneath the car covered in ATF.... Link to comment Share on other sites More sharing options...
Kranz Posted August 22, 2006 Share Posted August 22, 2006 How do you flush the system completely??? Link to comment Share on other sites More sharing options...
