terribleturner Posted August 21, 2006 Share Posted August 21, 2006 Im gonna have problems arn't i?? Is it just the drive shaft i will need too or is there anything else i would require?? Link to comment Share on other sites More sharing options...
paul mac Posted August 21, 2006 Share Posted August 21, 2006 i was under the impression that the box is the same its the diff that is different on the UK spec, i think it only becomes an issue when you put the UK diff in a JDM car as you would need the drive shaft but the gearbox itself would fit in either, i am not 100% on this though Link to comment Share on other sites More sharing options...
LeeT Posted August 21, 2006 Share Posted August 21, 2006 Its not the drive shaft you need, it will be the prop flange which you will be able to remove from your old box. Should be a straight swap apart from that Link to comment Share on other sites More sharing options...
terribleturner Posted August 21, 2006 Author Share Posted August 21, 2006 Ah good stuff Cheers. Link to comment Share on other sites More sharing options...
paul mac Posted August 21, 2006 Share Posted August 21, 2006 see i knew someone would turn up who knew what there on about lol Link to comment Share on other sites More sharing options...
MONKEYmark Posted August 22, 2006 Share Posted August 22, 2006 i have a uk lsd in my jdm facelift that was not a straight swop was about a inch or so different and would not line up.got it fitted in end guy modified a bit.also i have a spare uk auto box.there is a a slight difference onplug that measures speed i think jdm has 17 cogs and uk had 18 if i remember right.been a long time since i had box out. never had any other thing changed.well had the uk gearbox pump inside uk box swopped into my jdm box as the jap pump failed on me. can you not take lots of pics of box for future reference Link to comment Share on other sites More sharing options...
paul mac Posted August 22, 2006 Share Posted August 22, 2006 there is a a slight difference onplug that measures speed i think jdm has 17 cogs and uk had 18 if i remember right great reply Mark is this just an ecu input or is it linked to the speedo or both Link to comment Share on other sites More sharing options...
LeeT Posted August 22, 2006 Share Posted August 22, 2006 i have a uk lsd in my jdm facelift that was not a straight swop was about a inch or so different and would not line up.got it fitted in end guy modified a bit.also i have a spare uk auto box.there is a a slight difference onplug that measures speed i think jdm has 17 cogs and uk had 18 if i remember right.been a long time since i had box out. never had any other thing changed.well had the uk gearbox pump inside uk box swopped into my jdm box as the jap pump failed on me. can you not take lots of pics of box for future reference yep the UK auto LSD is the same size as the jap manual Diff. You would have needed to change the RHS driveshaft and should have changed the rear half of the prop to a shorter piece. Link to comment Share on other sites More sharing options...
LeeT Posted August 22, 2006 Share Posted August 22, 2006 great reply Mark is this just an ecu input or is it linked to the speedo or both The plastic cogs on the speed sensor can just be swapped between the boxes too Link to comment Share on other sites More sharing options...
paul mac Posted August 22, 2006 Share Posted August 22, 2006 The plastic cogs on the speed sensor can just be swapped between the boxes too thanks Lee Link to comment Share on other sites More sharing options...
terribleturner Posted August 22, 2006 Author Share Posted August 22, 2006 can you not take lots of pics of box for future reference Well i can take lots of pictures of a UK one, but the J-spec is on the car Link to comment Share on other sites More sharing options...
paul mac Posted August 22, 2006 Share Posted August 22, 2006 The plastic cogs on the speed sensor can just be swapped between the boxes too struggling to figure this out from the manual Lee, does the drive shaft flange have to come off or is it a case of splitting the speed sensor housing off the box Link to comment Share on other sites More sharing options...
LeeT Posted August 22, 2006 Share Posted August 22, 2006 struggling to figure this out from the manual Lee, does the drive shaft flange have to come off or is it a case of splitting the speed sensor housing off the box i'll take a pic for you at the weekend but basically, you just remove the sensor and the plastic cogs come out with it which can then be removed. You do not have to touch anything like the prop shaft flange. There is only 2 or 3 bolts holding the sensor in. Link to comment Share on other sites More sharing options...
LeeT Posted August 22, 2006 Share Posted August 22, 2006 actually, there is only 1 bolt holding the sensor in. Its the black sensor at the rear of the gearbox in the pic below http://mkiv.com/techarticles/auto_to_6spd_swap/remove_auto/DSC04004.JPG Link to comment Share on other sites More sharing options...
paul mac Posted August 22, 2006 Share Posted August 22, 2006 i'll take a pic for you at the weekend but basically, you just remove the sensor and the plastic cogs come out with it which can then be removed. You do not have to touch anything like the prop shaft flange. There is only 2 or 3 bolts holding the sensor in. thanks Lee, yeah i think i've sussed it page AT-100 in the manual shows a driven gear on the end of number 1 speed sensor, cheers mate Link to comment Share on other sites More sharing options...
LeeT Posted August 22, 2006 Share Posted August 22, 2006 thanks Lee, yeah i think i've sussed it page AT-100 in the manual shows a driven gear on the end of number 1 speed sensor, cheers mate I don't have a manual. I work it out by taking things apart and seeing how they are put together:D Link to comment Share on other sites More sharing options...
paul mac Posted August 22, 2006 Share Posted August 22, 2006 I don't have a manual. I work it out by taking things apart and seeing how they are put together:D i have the "luxury" of a cheap e-bay set lol, they are photo copys but have come in handy for torque settings etc, thanks for the help Lee you have put my mind at rest Link to comment Share on other sites More sharing options...
MONKEYmark Posted August 23, 2006 Share Posted August 23, 2006 yep the UK auto LSD is the same size as the jap manual Diff. You would have needed to change the RHS driveshaft and should have changed the rear half of the prop to a shorter piece. never changed any parts he just modified the bracket/mounting position if i remember right.works fine Link to comment Share on other sites More sharing options...
RedM Posted January 16, 2007 Share Posted January 16, 2007 Apologies for digging up this oldish thread but can someone who knows a thing or two condense all the replies and info in this thread into a reply that says exactly what;s need to put a UK autobox into a Jspec? FWIW, I have a Torsen diff. Does that make any difference to the length of the prop shaft? Link to comment Share on other sites More sharing options...
