Split Rim Change
Alex
No-one talking to you, Alex?? ;-)
This is a stab in the dark, but I would assume you would need...
For dissassembly:
Tyres off.
The right sized driver for the rim screws.
Possibly something to help release them if they are threadlocked in.
A tap to clean out the rim screw threads.
Some kind of surface cleaner to remove the old rim sealant.
For assembly:
A decent rim sealant (see Ash's thread for more details).
Surface activator for said sealant, if required.
The correct tightening torque / sequence for the rim screws.
Threadlock for rim screws, if required.
Some spare screws in case any got damaged during dissassembly.
The data sheet for the sealant / threadlock so you know the skinover / cure times.
Tyres on.
Inflate & balance.
Did I miss anything?
