eyefi Posted March 7, 2004 Share Posted March 7, 2004 Do u have any problems with yr battery to boot relocation, smells, spills, starting etc? Did u mount it right in the back of the boot (for the pendulum effect ) or over the axle? Did u go central or left or right? What did u do about venting it? Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted March 7, 2004 Share Posted March 7, 2004 Why do you want to move it?for the pendulum effect Do you mean making it more likely you'll crash? You can get around the acid issue by using a Varley race battery - Dry and can be mounted any way up you like - also light weight. Quote Link to comment Share on other sites More sharing options...
eyefi Posted March 8, 2004 Author Share Posted March 8, 2004 its an opportunity to move a reasonable weight from front to rear rather than just strip from rear. the further out back it goes the more it weighs (in effect) and the more momentum it would have if it swung. i think it would b better over the axle, but most relocates ive seen have it way out back. r the varleys expensive? Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted March 8, 2004 Share Posted March 8, 2004 Eyefi I have mine in the tyre well. There is a craddle ( Made from angle) the same size as the battery tacked to the well bottom, with two bits of studding and some angle holding it down. It's not going anywhere! Never been an issue an it's been there nearly 4 years. Quote Link to comment Share on other sites More sharing options...
eyefi Posted March 8, 2004 Author Share Posted March 8, 2004 is it a normal battery? Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted March 8, 2004 Share Posted March 8, 2004 Yep Halfrauds HCB 065 Quote Link to comment Share on other sites More sharing options...
Terminator Posted February 3, 2006 Share Posted February 3, 2006 Terry did you ever get any pictures of your boot battery? Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted February 3, 2006 Share Posted February 3, 2006 No bud but will next time I see the car. Quote Link to comment Share on other sites More sharing options...
