power and boost etc
Dave Henshall
i was bord today so i did a bit of maths...
a good stage 1 , 2.0 cossie 4pot engine running 1 bar of boost will make 270hp.
so 270/(4*1)=67.5 hp per pot,
and i wonderdd why the supras made much more power with only 0.8 bar of boost as std.. then reliased they are 6 cylinders..
re work the above and put the supra numbers in...
67.5*(6*0.8)=324 hp
almost exactly what the TT is as std ...
i know this is simple stuff, but int maths brilliant ;)
67.5*(6*0.8)=324 hp
So according to your maths, if you take a BPU Supra running 1.2 Bar boost you will get 486BHP:D
Can't see how this is technical (pure speculation) so have moved to Supra Chat. :angrymod:
You cannot like for like compare 2 completely different engines with completely different turbo setups and assume 1 bar of boost on each is equal if they have the same no. of cylinders.
Brian.
...i know this is simple stuff, but int maths brilliant ;)
It is simple indeed, just not as simple as you think it is.:D
Boost and power do not have a linear relationship, and in any case you should be using absolute pressures, not boost.
